Old 12-17-2016, 10:46 AM
savage sausage's Avatar
savage sausage savage sausage is offline
Default Wiring Help
ok so now have all my bits to convert AC to DC using a Reg/Rec powering a 2 button switch (HI / Lo) to a LED headlight and Rear tail/brake light.
Using the ducati energia yellow (+) to the yellow of the RR
and red ( - ) to the white of the RR
as i understand the wire from the tail light needs to run to the lightswitch which will be supplied with DC power from the RR.
the power feed from the rear brake switch should also tap into the live from the RR
The problem i am struggling to understand is the light switch and bulb wiring
3 wires from the bulb H / L & (earth)
it has 2 push in & out switches in total 4 wires.
I assume the switch is only live when it is pushed in.
here is a wiring diagram i have drawn to show you if it is correct
also i wiring diagram with the switch i bought
Old 12-18-2016, 11:23 AM
thats all folks ill work it out mi sen
Old 12-20-2016, 04:08 PM
Neil E. Neil E. is offline
Did you manage to sort it out? Perhaps a more basic wiring diagram will help. Most of the work is identifying the switch wires and figuring out their function.
2011 EC250E
Old 12-23-2016, 05:33 PM
Thanks neil
Ive wired up 95% just got to test ive got the switch and headlight configuration right before i crimp the bullets and heat shrink over them....i learnt the hard way in the past.
those wiring diagrams make my head spin, however the diagram you sent me helped i did most right upto now just those damn switches and headlight connectors that may be a pain, i really appreciate the help you have given me.
maybe hopefully in the next new year ill be coming to live in canada..yay
GG 05 450 wiring help chaddlez Enduro Electrical & Wiring 0 07-02-2016 06:00 AM
EC 300 Wiring Help Please seb421 Enduro Electrical & Wiring 0 02-03-2015 11:14 AM
2002 ec300 light wiring and speedo wiring help needed. andy176 Enduro Electrical & Wiring 0 02-04-2014 07:38 AM
wiring for ac and dc wence Enduro Electrical & Wiring 8 12-29-2009 01:08 PM
wiring a MC crem55 Enduro Electrical & Wiring 3 04-30-2008 07:12 PM
