Old 01-12-2017, 09:36 AM
muddertrucker muddertrucker is offline
Default Weird jetting!
So i took my carb off today to verify what i had in my notes because the jetting values i had were no were near what everybody elses are.
My bike is a 2011 ec 300 that i think is all stock but the jetting i have is 145 on the main and 38 on the pilot. I have no idea wich needle is in there and cant see any writing on it. The slide is a number 7.
The bike runs good, smokes only a little and the plug is actualy pretty dark.
Any ideas as to why my jetting is so different?
Old 01-12-2017, 10:44 AM
CanGasser's Avatar
CanGasser CanGasser is offline
The main is too small, the bike will be asking for more fuel. I run a 40 pilot and # 2 from top for the needle. I'm about 5hr from you.
Current: 2007 GASGAS 300EC 2004 KTM 250 SX 2003 YZ450F
Old 01-12-2017, 10:55 AM
Theoreticly it should i know. But it definatly is running good.
Just wondering what could make it need such a small main jet.
Old 01-12-2017, 12:07 PM
Neil E. Neil E. is offline
Are you actually riding hard enough to get on the main jet? The main jet is mostly controlling the mixture past 3/4 throttle and you've got to be riding with the throttle almost pinned to see what effect your main jet has.
A small main would require a needle with a very small bottom diameter.
2011 EC250E
Old 01-12-2017, 12:18 PM
webmaster's Avatar
webmaster webmaster is online now
Administrator
Are you sure it isn't a 175 main?
If you don't see any markings on the needle it may be a jetting kit where the markings were removed to keep someone from copying it. e.g. old LTR jetting kit. This is a keihin needle.
If you don't know which needle it is - I would pick up a needle suggested elsewhere here - e.g. "suzuki needle" or "yamaha needle"...
With all replacement (improvement) needles - you typically run a richer pilot jet and reduce idle setting to better separate the carb circuits (high/low). My experience (which is a bit dated) is that you should see a 42-45 pilot - maybe a 40 - but definitely not a 38 if things are set up "well" (given conditions are not extreme).
Old 01-12-2017, 01:03 PM
You can see it pretty good in the pic but in real life it's even more clear that it's a 145.
And no I don't tend to reach above 3/4 throttle except on the rare occasion.
2011 EC 300
Old 01-12-2017, 01:13 PM
Here's a pic of the needle.
2011 EC 300
Old 01-12-2017, 03:13 PM
Is it a 36mm carb? Some 2011 models came with them.
Old 01-12-2017, 03:39 PM
No it's the 38, I was just looking it up to see which one I had.
I have a left over 42 sj from my kdx220 but I'm kinda having a hard time seeing if it's compatible.
2011 EC 300
Old 01-12-2017, 04:56 PM
Anders's Avatar
Anders Anders is offline
Perhaps your 145 main has been bored out? If the needle is modified the main could be too.
Sent fra min E5603 via Tapatalk
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
weird location but some good gg action knobbyboy Pictures & Videos 3 10-01-2014 03:03 PM
A Few Jetting Basics (ie Jetting 101) n_green Enduro Intake/Carburetion - 2 stroke 8 05-23-2014 05:42 PM
Weird steering problem?? wence Enduro Chassis & Body 13 01-01-2013 06:32 PM
Weird one - oil leak blitz11 Enduro Engine - 2 stroke 2 09-25-2012 12:12 PM
Weird noise? K Vee Gee Other GasGas Bikes/Quads 1 04-09-2012 11:25 AM
