Old 09-02-2006, 12:33 PM
LTRace's Avatar
LTRace LTRace is offline
Default FAQ; Suspension baseline settings
2004 to 2006 Models;
A good baseline setting for your Ohlins shock clickers with stock 52 nm spring, stock valving and fresh fluid would be around this range;
Rebound, 14 to 16 clicks out.
Compression, 17 to 19 clicks out.
High speed compression (the 17 mm hex with rubber boot around it) up to late 2005 would be 3.25 to 3.5 turns out. Late 2005 and 2006 has a different HSCD adjuster, 1.5 to 1.75 turns out.
The stock 52 nm spring is ideal for 180 lb. rider, +/- 15 lbs max. Your preferences may dictate a variation from this.
Set sag (you on board) to 105 to 108 mm. Your preferences may dictate a variation from this. (See more notes towards the end of this post)
Spring pre-load (spring free length minus set length) should fall between 10 to 15 mm
This is a good place to start and fine tune from there.
For the 45 mm Marzocchi fork with standard .42 kg/mm spring, stock valving and fresh fluid would fall in this range;
Rebound, 10 clicks out.
Compression, 17 clicks out.
Fluid level 100 to 110 (total range of adjustment is 80 mm to 130 mm)
Stock fluid viscosity is 7.5
Pre-load (spring free length minus set or installed length) 5 to 7 mm.
The stock springs are suited for a 180 lb +/- 15 lbs. rider. Your preferences, ability, load (water, tools, etc.) and riding terrain will vary the rates (both front & rear) and adjustments. These are specs for the 200,250,300 2 strokes.
Chassis adjustments;
The upper fork tube position in the clamps is not a suspension (action) adjustment, it is a chassis adjustment and will determine the steering and higher speed stability.
With the fork caps flush to the upper clamp, you will achieve better straight line stability, slower turning charachteristics. (think of it like a raked out chopper)
To the extreme of say 10 mm of upper fork tube exposed from the upper clamp, you will have sharper steering and less higher speed stability.
The rear sag may be used to fine tune the handling charachteristics as well. With more rear sag, say 115 mm, the rear sits lower and rakes out the front (slower steering, better stability)
With less rear sag, say 95 mm, the rear will ride higher and allow it to steer quicker but will give up stability.
Combine all of this, and throw in the position of the rear axle position in the swingarm and you have allot of variables to fine tune or totally goof up your bike for your specific needs!
Les
www.lt-racing.com
Port Orchard, WA USA
Old 09-02-2006, 07:29 PM
the eel the eel is offline
Great stuff ... thank you.
Old 09-03-2006, 02:07 PM
iancp5's Avatar
iancp5 iancp5 is offline
snipped .............
Does this apply to a 2003?
I guess there is no separate HS damping adjustment?
Thanks
Old 10-08-2006, 09:01 PM
gasIdaho gasIdaho is offline
Default High speed compression Ohlins setting question
I was going through and updating my suspension settings as per Les's suggestions. My High speed compression (the 17 mm hex with rubber boot around it)..goes out a total of 4 turns. I'm curious as to which setting to go with? (up to late 2005 would be 3.25 to 3.5 turns out. Late 2005 and 2006 has a different HSCD adjuster, 1.5 to 1.75 turns out.)
thx/Mike
05' EC300
Old 12-03-2007, 03:00 AM
mow mow is offline
Default baseline settings for sachs
Does anyone have the settings for the 2007 model with the sachs rear shock, I have an ex-ISDE bike, has the black swing arm.
Thanks
Old 12-04-2007, 07:42 PM
kim kim is offline
All of the ISDE bikes came with Ohlins shocks as far as I'm aware.
Call Linton at Dirt Action in Chch, he should see you right.
K
08 TXT 300
06 Gasgas EC200
03 Gasgas EC300
05 Pampera 250
Old 12-05-2007, 02:58 AM
mow mow is offline
Default Sachs
Hey thanks for that, It is very much a ISDE bike still has all the paint marks on all the parts, it was ordered with the sachs rear shock & to be fair my last gasser had the Ohlins & like the sachs better, what I was after is the high speed setting as the manual has no information on it at all & the NZ importer does not know ether.
Old 12-23-2007, 08:41 PM
gasgasman's Avatar
The following tips are off the Too Tech Racing web site:
Setting sag
http://www.tootechracing.com/suspension_tips.htm
Setting static sag
http://www.tootechracing.com/Static%...sion%20Tip.htm
Tons of suspension info here
http://www.tootechracing.com/Home%202nd.htm
Old 12-27-2007, 10:08 PM
BIG TOOL BIG TOOL is offline
Good Stuff from all... But I noticed that there is no tutorial or baseline for the '07 SACHS shock... Basic clicker settings and even as simple as which is the high speed adjuster and which is the low speed adjuster... Just thought some of you guys might be able to give a better explanation than I could...
Old 01-06-2008, 09:38 AM
tonipurhonen tonipurhonen is offline
Anyone have any ideas for basic clicker settings for the 07 sachs and öhlins shock.
And how about 07 Marzocchi fork.
Gas Gas EC 300 09 Basic Suspension Settings snaissidis Enduro Suspension 0 03-16-2009 04:05 PM
2005 baseline settings stay_upright Enduro Suspension 0 01-26-2009 08:37 AM
450 fork settings? splint Enduro Suspension 0 10-14-2008 03:30 AM
baseline ohlins setting fullthrottle Enduro Suspension 5 04-26-2008 08:15 AM
EC300 Baseline settings Magellan Enduro Suspension 7 08-26-2006 06:30 AM
