Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > Other GasGas Bikes/Quads
Other GasGas Bikes/Quads Trials, Pampera, Wild HP, etc.
Old 03-04-2017, 11:40 AM
Blambo Blambo is offline
Angry Front wheel not central
My front wheel runs WAY too close to the RH fork (left as seen from the front).
I've taken it all apart and checked it against the parts diagram and logically and it's all 'correct'.
So, what has changed ?
It can only be that I changed the wheel bearings...
If the RH bearing wasn't seated (sitting proud) that would HELP, i.e. push the wheel towards the centre.
Has anyone seen this before ?
What about the DISTANCIADOR RUEDA DEL.17.2MM INT / FRONT WHEEL SPACER BEP250218019 ? part 11 on page 3 of the parts book.
(this is inside the wheel, between the bearings).
I remember when I changed the bearings that this is non-symetrical, but there didn't seem any obvious reason to put it in one way or the other.
I guess I must have got this the wrong way round.
Shame I'll trash at least one of the new bearings getting it out...
Sigh,
Mike
Old 03-04-2017, 12:44 PM
gasgasman's Avatar
Is the rotor centered with the caliper?
Old 03-04-2017, 11:15 PM
Picture? Year model? Bearing part numbers that you replaced? Did you confirm them the same size/make?
Old 03-05-2017, 05:31 AM
Default details of art numbers (interesting!|)
Hi,
It's a mk2 Pampera 250 (2002).
I used AllBalls bearings, labelled for Pampera their part # 25-1135
Everything looks right, the brake works ok, but the wheel is just too close to one fork leg.
Part numbers are interesting...
The bearing numbers were 6003, same as I used in the rear.
But the parts manual has 2 different numbers for the front wheel bearings.
R=BEP250218007 L=BIE500118054
The supplied bearings were 6003 same as the rear bearings, both labelled as 6003, BIE500118054 in the parts book.
So, should I have had one 6003 and another different one ???
I have e-mailed AllBalls to see what they say...
Mike
Old 03-05-2017, 09:11 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Originally Posted by Blambo View Post
Hi,
Mike
Did you look at the numbers on the bearings that you took out of the wheel? Do you still have them in order to check them?
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 03-05-2017, 09:39 AM
gasgasman's Avatar
If the rotor is centered, you will have to adjust your spokes to shift the rim over.
Old 03-05-2017, 09:50 AM
Jim Cook's Avatar
Thumbs up
Girard,
That is accurate, but seems extreme to me when he only need the proper bearings and spacer alignment for things to work correctly.
I will check my parts book, but for now I'm speculating that there might be a mistake on the bearings in the All Balls kit.
Another avenue is to ask a (trials) dealer who stocked the Pampera parts for the information or the correct bearings.
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
Old 03-05-2017, 10:37 AM
But doesn't the caliper have a degree of lateral movement (to cater for bent disks)?
2003 txt250 Pro
2013 Ossa 280i
Old 03-06-2017, 10:31 AM
slocalspode's Avatar
slocalspode slocalspode is offline
I am with Jim on this one.
The Pampera does use different bearings on the front wheel.
I believe one is a different width. I'd need to pull the front wheel to check
if the O.D or I.D is different.
The caliper is solid mounted to the fork on one side. The other half slides
in and out to compensate for the brake pad thickness.
On the disk rotor / caliper side there is a thick washer / spacer between
the fork and the bearing.
I can take pictures of how mine is set up if needed.
Cheers, Jeff
Originally Posted by Jim Cook View Post
Girard,
Jim
Old 03-06-2017, 11:14 AM
Jim Cook's Avatar
Thumbs up
Cheers, Jeff
Thank you Jeff. I think the bearing number will do him a lot of good. The spacer dimensions are also going to help him a lot.
You, like GasGasman and many others on this forum, have always been willing to help other riders. Kudos to all of you who make this forum such a great place to come for GasGas information and help!
How is your bike doing? Do you still have that little supermotard?
Good Riding and Thank You!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
'94 Husaberg FE350
'86 Yamaha IT200
Let's go riding!
Cant get my front wheel off mwinschel Enduro Chassis & Body 7 03-05-2016 01:13 AM
FOR SALE, 250XC forks, NEW fender, front wheel, front wheel bearings iamyvr Parts 5 07-27-2014 08:18 AM
Front wheel ? Silver Enduro Chassis & Body 2 04-20-2009 05:33 PM
Will anything other than a GG front wheel fit a GG? cal_tony Enduro Chassis & Body 7 11-08-2008 09:21 AM
