Old 05-29-2017, 02:11 AM
Rampart Rampart is offline
Default FAN KIT FOR EC300 question
Hi all
Wanting to install fan on my gg. But it's not original kit. So i wondering what "voltage rectificator from AC to DC" is for, and can i install fan without it?
Old 05-29-2017, 02:16 AM
Anders's Avatar
Anders Anders is offline
The fan is then most likely a DC fan. What model of bike do you have? Only the last models have DC system. If you have any older bike you must install the rectifier since it has an AC system..
Sent fra min E5603 via Tapatalk
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 05-29-2017, 05:12 AM
the fan is the one that comes on the GG trials bikes.
https://www.greenlandmx.com/en/p/oem...ifier-txt/7008
I have one on mine, but since it does not have the battery i have the rectifier. I will find out what information is posted on the unit later today.
2003 txt250 Pro
2013 Ossa 280i
Old 05-29-2017, 07:14 AM
I have ec300 2011
Old 05-29-2017, 08:23 AM
with or without e-start is the actual question i think.
sorry nothing marked on my rectifier, may have worn off
2003 txt250 Pro
2013 Ossa 280i
Old 05-29-2017, 10:14 AM
http://www.motocrosscenter.com/shop/...c-dc-3251.html
2003 txt250 Pro
2013 Ossa 280i
Old 05-29-2017, 11:00 AM
Neil E. Neil E. is offline
That rectifier should be an easy install. The black and red are your DC output to the fan. The yellow and white wires are for AC. You need to locate the yellow wire that comes out of your stator and connect into that circuit with the yellow wire on your rectifier. The white wire on the rectifier is then grounded to complete the circuit. The fan will run whenever the engine runs.
In the kit there is a thermoswitch you can add to the circuit. Put it in series with the white wire. This will let the thermoswitch ground the rectifier to create your DC for the fan. This is the way the kit is intended to be used so the fan engages only when the coolant reaches the temperature limit.
On the AC input it does not matter if you hook up the wires opposite (connect the white and ground the yellow).
2011 EC250E
Old 05-29-2017, 11:17 AM
I fitted a handlebar switch (the same as the map switch) and turn it on when the going gets tough or v slow
With the fan fitted (but not turned on) the bike will boil easier as the fan cowling will reduce natural airflow so once fitted remember to use it
2003 txt250 Pro
2013 Ossa 280i
Old 05-29-2017, 01:20 PM
Thanks all, but i don't understand - should i install rectifier with fan, or i can install it without rectifier?
Old 05-29-2017, 04:04 PM
You should use the rectifier.
2011 EC250E
12 EC300 mapping question knocklife Enduro Electrical & Wiring 1 09-24-2014 12:45 AM
06 EC300 Question ECTim Enduro Electrical & Wiring 5 08-27-2014 04:29 PM
Starter question 2011 EC300 iamovru Enduro Electrical & Wiring 3 02-17-2014 12:01 PM
Gas Gas ec300 plastics question. Tricky Enduro Chassis & Body 4 01-07-2014 10:55 AM
EC300 Dim Electrics Question rogerc Enduro Electrical & Wiring 2 03-02-2009 11:47 AM
