Old 02-24-2008, 08:24 PM
g dirt g dirt is offline
Default 07 GG300EC - small hole at btm. of engine?
What is the small threaded hole for on the underside of the engine? It is located between the oil drain plug and the crankcase drain plug.
Also what is an approved sparkplug by NGK or Champion that is equal to the denso plug that comes stock on the 300?
Old 02-24-2008, 08:46 PM
GMP's Avatar
GMP GMP is offline
I beleive its used in mfg for a jig. The older cases ran the ignition drain to a hole like that but the hole in my '07 250 is blind. NGK BR8EG or cheaper BR8ES works fine.
Old 02-25-2008, 08:12 PM
GasGas's Avatar
GasGas GasGas is offline
What do you guys use for a plug in your 125 GMP? I've been using a BR9ES. Just wondering if a 8 wood last better in the woods. The 9's seem fine on the track but not so much in the woods.
Old 02-25-2008, 09:16 PM
GMP's Avatar
GMP GMP is offline
The 125 is my nephew's bike, and sometimes when running real slow and technical stuff it will foul a BR9. The BR8 works better in these conditions. If its open enough where the bike is on the pipe a lot the 9 gives no problems and we run it. Jetting is very good, and the bike makes good low end for a 125. I suspect that some head work may clean this up.
Old 02-26-2008, 05:48 AM
GasGas's Avatar
Thanks, I find the same with the 9's. I will be trying an 8 at the next scramble.
Hole In Cylinder PEB Enduro Engine - 2 stroke 1 09-07-2010 10:19 AM
help guys,which bike gg250ec or gg300ec nickp General Discussions & Announcements 9 08-04-2010 08:22 PM
Small bike and ATV ban. Ud_luz General Discussions & Announcements 22 05-04-2009 01:06 PM
Cyl/Head o-rings why so small Treesmacker Enduro Engine - 2 stroke 9 02-19-2009 11:09 PM
M6 hole under engine? moff747 Enduro Engine - 2 stroke 2 03-19-2008 10:48 PM
