Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Trials Technical Forums > Trials Engine
Trials Engine Cylinder, Piston, Tranny, Bearings, Clutch, Pipes & Silencers, etc.
Old 09-12-2017, 09:40 AM
Satanic Mechanic Satanic Mechanic is offline
Default Pinhole in case
Upon splitting the case on an '03 280 I found a pinhole leading to transmission side. I'm a Harley tech and don't have a lot of experience in 2 strokes, but I don't think the hole should be there. Any info would be appreciated
Old 09-12-2017, 11:08 AM
gasgasman's Avatar
Welcome to the forum.
Does it look like a casting flaw or a drilled hole?
Old 09-12-2017, 04:08 PM
Thought it was cast in at first
Old 09-12-2017, 06:06 PM
gasgasman's Avatar
Looks like it is drilled.
That does not seem right, as the crank case should be totally sealed from the transmission.
I would contact Jim Snell as he is the trials bike guru.
http://www.trialspartsusa.com/repair-services.html
Old 09-12-2017, 06:08 PM
gasgasman's Avatar
https://www.youtube.com/channel/UCUw...qPZ175A/videos
Old 09-13-2017, 08:57 AM
Much obliged
Pinhole leak in radiator - suggestions motorhead Enduro Engine - 2 stroke 9 12-21-2015 12:39 PM
Case sealer? SS109 Enduro Engine - 2 stroke 1 11-19-2014 02:52 PM
Case saver Danj56 Enduro Engine - 2 stroke 2 09-17-2012 09:11 PM
Red oil in case?? What is it? tsmith Enduro Engine - 2 stroke 22 05-23-2012 11:47 AM
cracked case jimjim Enduro Engine - 2 stroke 3 09-01-2011 07:34 AM
