Old 10-12-2017, 09:47 PM
Samkjenn's Avatar
Samkjenn Samkjenn is offline
Default Which 2t oil
Ok I?m sure this isn?t the correct place to post this but, I have have searched and searched and haven?t found an answer. I was out riding with my wife and sister who are both brand new riders and I fouled my first plug in 10+ years of riding smokers. So with that being said the bike is jetted for 50:1 and I have been running Amsoil dominator and noticed it?s a bit spoogey. I don?t have a readily available Amsoil dealer to get ahold of interceptor, so what are some good alternatives so I can still lug the bike quite a bit?
Old 10-12-2017, 11:08 PM
Aggie Aggie is offline
If your plug is fouling it?s likely a jetting problem. Oil ratio doesn?t change with jetting. If the bottom rev range is causing spooge then you probably need to change the pilot/adjust the needle. I don?t believe brand of oil matters as long as it?s synthetic.
Another reason for fowling could be that you’re using the wrong plug. You need a fine wire type plug, IE the EG type from NGK. The regular electrode plugs are prone to fouling in two smokes.
Old 10-13-2017, 06:37 AM
PFD023 PFD023 is offline
I was fouling plugs like crazy when I was using the race Motul oil. Switched to an oil with lower flash point and problem solved.....for me. Now using Amsoil Interceptor.
Old 10-13-2017, 07:52 AM
Good discussion and some comparisons of flash points here... https://thumpertalk.com/forums/topic...sh-point-info/
Old 10-13-2017, 05:21 PM
It may help to re-pack the muffler and burn/clean out any build up. I noticed a significant decrease in spooge after doing this on my Turbine Core 2.
Old 10-13-2017, 05:52 PM
Samkjenn's Avatar
I just repacked the stock muffler 2 hours ago but after reading that write up on thumpertalk I went ahead and orders some maxima bio 2t. It has a 180 flash point which is 14 degrees lower than Amsoil dominator. So when it arrives from motosport I’ll go run it and see. And I put a br8es plug in it had an iridium br7eix in it.
Old 10-13-2017, 06:42 PM
Zman's Avatar
Zman Zman is offline
The Klotz Motorcycle Techniplate works well and has little spooge.
Old 10-13-2017, 06:47 PM
(F5)'s Avatar
(F5) (F5) is offline
Oh yay an oil thread.
Get the right needle and replace the plug once a year as it wears out. Any decent oil. These bikes review low.
If your needle is the std N1EF it will be rubbish.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 10-13-2017, 08:21 PM
Samkjenn's Avatar
I don’t have the stock needle the PO had the rb carb mod and head done, I’m hoping with the lower flash point it should help a bit and it’s going to get a top end this winter anyway.
Old 10-15-2017, 02:36 AM
Motul 710 is the one for lugging
2003 txt250 Pro
2013 Ossa 280i
