Old 02-06-2018, 02:08 PM
carloxgsxr750 carloxgsxr750 is offline
Default FSE 450 Map 05/06/07
Good I present myself from Madrid FSE 450/06.
Greetings to all ... Apologies for my English.
I have a problem with my 2006 FSE has a switchboard with map 05 and it works fine.
I put the map of (2005 values 2006) and (2005 values 2007) and accelerates up from 1900 rpm to 6500 and then remains accelerated at 3100 rpm and takes about 10 seconds to return to normal idle 1900 rpm.
It does so in the two maps, A and B, and with maps 2006 and 2007.
The TPS is new, is set to its value +290 and reset.
The CO is at +17.
He keeps doing it.
I can only put your map of 2005 and this does not, go up and down well of laps and adjust the idle ok.
Any ideas?
I upload the maps to share them.
https://mega.nz/#!wrRUhBjY!fkRCBzvJU...V7egxzl3b4BAVE
Greeting and thank you very much.
Carlos
Old 02-23-2018, 04:01 PM
I already solved the issue that was accelerating the bike. It was because of the TPS setting that I had to go down to 5.95? and reset it with the IAW. The idle was low at 1800/1900 Rpm and I could put the map of 2006 and 2007 finally leave 2006 I think it was somewhat softer.
What is the correct value of the CO?
I left it at +20 and it was +16
Greeting and thanks
Carlos
