Old 03-06-2019, 10:57 PM
yowie05 yowie05 is offline
Default fork changeover
hi guys,
I have an '04 EC300 with the 45mm Mazzochi forks. 12 months ago i had them rebuilt and they are leaking already. Anyway i have an '06 KX450 with Ohlins 48mm forks and an original GG triple clamp set to accomodate the 48mm forks. Considering its not going to cost anything except time I'm wondering if it is worth changing to the ohlins forks or not. Actually just thought about the width between the forks at the triple clamp, ill have to measure that so i can use the complete front of the KX. Another way would be to determine the bearing changes needed to take the KX triple clamp then the wheel would fit with no changes to spacers and axle.
Any input is muchly appreciated.
Old 03-06-2019, 11:07 PM
(F5)'s Avatar
(F5) (F5) is offline
Extremely I would have thought if you intend to keep it. But I'd expect the spring rate, preload and likely valving will be more suited to a top heavy 450 falling out of the sky.
Mate has just done with YZF450 forks and it is good when travel is being used but too 'everything' most of the rest of the time.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 03-30-2019, 02:39 AM
Funny you say a top heavy 450. book wieght on the 04 EC300 is 109kg and the book weight on the 06 KX450 is 104kg. anyway Ive done the swap. Ive got everything on softest setting and its actually pretty reasonable. id say the spring is too heavey for my wight as im only 65kg so am looking to get lighter springs prolly go for about .40kg/cm and not sure on the valveing as thats a bit beyond my expertise. Yup the plan is to keep the bike, id love a newer bike with Estart but $$ is the problem. for about $1k i should have this way better than ill ever be able to handle.
19 EC300 Six Days
04 EC300
00 KX125
06 KX450(deceased)
Old 04-05-2019, 03:51 PM
So far every fork I've taken apart that has a reputation for being "harsh on small square edge hits" has simply needed a smaller clamp shim. I've also learned to remove any excess bleed and never use a crossover.
12 months is a decent time between servicing if you're riding often. If you're worried then change the bushes, all balls do decent sets very cheap.
2016 RM-Z450
Old 04-23-2019, 09:58 AM
What is excess bleed and using a crossover? Also clamp shim. Im new to working on suspension. I've replaced the oil to spec lvls but havnt gone any further in than that. I need to change the springs in the ohlins forks as they are not for my weight. I'm 65kg so even if they standard weight springs (.46) still too stiff for me. If i can ill get some .38 springs. Unsure on how to do valving so ill prolly have to leave that or pay someone.
19 EC300 Six Days
04 EC300
00 KX125
06 KX450(deceased)
Old 04-25-2019, 07:45 PM
rvktm rvktm is offline
how old are the ohlins .are they cartridge or open type on your marzochis how much play is there the in the legs [wheel of grab leg ]iv just had to shim the slide bush to stop my 45s leaking . if you ride mostly in the woods the marzocchis are best
Old 04-27-2019, 04:33 PM
The online are off an 06 kx450 other than that no idea. I had the mazocchis rebuilt about 12 months ago but not change the springs rate or revalved to my weight. My plan is to now do that but wondering whether to do it to the ohlins or the zoks.
19 EC300 Six Days
04 EC300
00 KX125
06 KX450(deceased)
Old 04-28-2019, 12:56 PM
what type of adjuster do the ohlins have on top is it a black knob or two bolts and a slot adjuster in the middle in gold
Old 04-29-2019, 01:02 AM
well they dont have a black knob. they are the same as these https://www.ebay.com/itm/2006-06-Kaw...-/263863429748
19 EC300 Six Days
04 EC300
00 KX125
06 KX450(deceased)
Old 05-01-2019, 06:44 PM
there the std showa think 47 cc forks
fork clamp bolts and fork oil level gassergrant Enduro Suspension 2 02-16-2016 04:08 PM
not all 5 wt fork oil is the same! matt_tidball Enduro Suspension 3 04-25-2012 06:21 AM
Fork oil?????????? Wicitup Enduro Suspension 3 02-15-2012 10:53 PM
fork seal change sachs fork Madhead Enduro Suspension 13 01-13-2012 07:49 PM
LTR fork Oil PEB Enduro Suspension 5 09-10-2008 08:07 AM
