Old 06-02-2019, 04:35 PM
GG221 GG221 is offline
Default Wet mod for 2018 starter
I have read people mentioning the wet mod for the starters so just a couple quick questions. Basically what I am understanding is to plug up the hole in the bottom of the ignition housing, remove the starter and bendix and clean all of the grease off everything , put it back together and dump 4 ounces of 5W fork oil into the bendix assembly. Is that it? Am I missing something or any other tips? Also does this oil ever need to be changed?
Old 06-02-2019, 05:16 PM
Gasser Nate's Avatar
That is it mate. You can add a small vacuum fitting up the top so it can breathe as well. Beta do not but I thought it was a good idea too on mine. No issues at all what so ever with the electric start. It spins the quickest out of all my mates and always engages. I would just change it when you do a top end.
Old 06-02-2019, 09:19 PM
Thanks. So by doing this there is no worry about getting oil onto the stator?
Old 06-02-2019, 09:45 PM
The stator will be covered in oil, I have used a synthetic gearbox oil in mine and never had an issue with this Gassy or about three others I have done it to.
Old 06-02-2019, 09:57 PM
Ok thanks for the help. One more thing, is 4 ounces the right amount? I see for KTM it was 4 but then people started doing 2 instead. And for the vacuum is it necessary, does it need to be drilled and tapped, and does it go on the ignition housing?
Old 06-02-2019, 10:40 PM
I am in metric land. I have no clue what an ounce is! 🤣 I think I run about 75 millilitres. Yes I drilled and tapped the stator cover. Somewhere up top and away from wiring/accidental damage will be fine.
Old 06-03-2019, 02:13 PM
(F5)'s Avatar
(F5) (F5) is offline
We did a mate's. It blew some oil out of it. Then drilled and tapped an empty grease fiting and put a tube upwards towards under tank on it. Great ever since.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 06-03-2019, 03:04 PM
Ok thanks again. 75 milliliter is 2.5 ounces
Old 07-15-2019, 06:20 AM
So the bendix gears are sitting above the oil so they will be dry until things start spinning?
Old 07-15-2019, 08:12 AM
Pulled my bendix cover the other day for the first time to see how it is going after a month of sitting around, still covered in oil and no wear to the bendix cover at all.
2018 Starter Fix Thread - Continued. webmaster Enduro Electrical & Wiring 162 04-26-2023 02:57 AM
EC 300 2018 starter problem eralha Enduro Electrical & Wiring 74 10-08-2020 03:41 PM
Eectric starter 2018?s.. GasgasGP Enduro Electrical & Wiring 86 11-21-2018 10:03 PM
2018 Starter Delete nhgas Enduro Electrical & Wiring 1 11-10-2017 07:58 PM
