Old 06-07-2019, 05:12 AM
andrius7 andrius7 is offline
Default Slipping cluch
Hi all, just fitted new set on my fse, after a half hour of riding it startas to slip on 4,5,6 gears
Old 06-07-2019, 05:17 AM
Anders's Avatar
Anders Anders is online now
Did you check the spring lengths? Perhaps they are worn?
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 06-07-2019, 05:57 AM
arminhammer arminhammer is offline
Too much fluid in the res.
Old 06-07-2019, 08:40 AM
Į left old springs, new ones are too long, but į might be wrong
Old 06-08-2019, 02:00 AM
Gasser Nate's Avatar
Were they genuine plates? Did you measure the thickness of them? Did you pre soak them in oil before fitting as well?
Old 06-08-2019, 08:15 AM
OK, problem solved, just tighten 3 springs
Kickstart slipping. GGRider01 Enduro Engine - 2 stroke 11 01-27-2016 01:46 PM
DOT5 brake fluid in AJP cluch MC alecsstefan Enduro Engine - 2 stroke 12 05-25-2010 01:30 AM
Slipping kickstarter Warwick Simpson Enduro Engine - 2 stroke 10 07-11-2008 03:26 PM
Slipping clutch nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 12 06-18-2008 08:14 AM
