Old 07-07-2019, 08:34 PM
V8Astro V8Astro is offline
Default First post. Engine setup
I?ve been lurking here for a while. Lots of good info and I thought I might post to show what?s going on. I have a 2013 EC300e supermoto. I ride it exclusively on the street. I felt it could use a little more top end since this engine has tons of low and mid power.
I?m adding another base gasket under the jug in an effort to get my piston flush with the exhaust port floor. The bike has 17hrs on it and the piston looks fine so I?m going to reuse it. After that I?m going to check the squish and have my machinist friend make any adjustments to my S3 head. The S3 head made a big difference but I installed it before I spent hours reading this forum.
I have a Scalvini pipe and silencer in order. Should show up in a few weeks. Any other input from the pros?
I never would?ve got this far if not for this forum. Thanks everybody!
File Type: jpg 49355500-64C1-4E10-A407-DCFD3E07042F.jpg (132.0 KB, 36 views)
File Type: jpg 12FB0FDD-F178-4C8A-9C9A-E0833C9AB3A0.jpg (106.6 KB, 35 views)
File Type: jpg A8BB6E58-0998-478A-87CA-61FFE763CEF2.jpg (114.8 KB, 27 views)
Old 07-08-2019, 03:28 AM
(F5)'s Avatar
(F5) (F5) is offline
Have you tried new needle or mains?
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 07-08-2019, 08:06 AM
Yeah JD jet kit was one of the first things I did
Old 07-08-2019, 08:34 AM
One question...the jug currently has a steel shim type gasket under it. Is it ok to stack a paper gasket on top?
Old 07-08-2019, 02:38 PM
(F5)'s Avatar
Yes but use 3Bond or flexible master gasket with it.
I don't understand people's fascination with the bottom of the exhaust port. The top is the important part. Given that raising it independently is difficult.
You should measure the compression ratio properly (with a burette). A screw in pressure gauge is misinformation. YouTube it, then you can adjust it appropriately to account for your fuel and what sort of overrev you want.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 07-08-2019, 08:20 PM
You know how the bike runs. Gobs of power down low and in the mid range. I need to shift my power up higher for my needs. From what I?ve read this is the simplest path to that goal
Old 07-09-2019, 02:36 PM
(F5)'s Avatar
Pipe is a factor and see you have something on order, just no idea of that make.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 07-09-2019, 03:39 PM
Davehuge's Avatar
Davehuge Davehuge is offline
I assume on the road you can run much longer gearing.
Have you tried different sprockets/smaller rear sprocket?
Old 07-09-2019, 08:07 PM
Yes. Currently running 13/38
Old 07-09-2019, 08:09 PM
Scalvini pipe and silencer. I hope it does what I need
Post in the right forum gasgasman General Discussions & Announcements 3 09-07-2015 06:27 PM
My first post. Adss General Discussions & Announcements 1 05-29-2013 03:52 PM
First Post papa_j Pictures & Videos 12 03-08-2012 07:28 AM
First Post JdB Enduro Suspension 20 05-26-2008 09:33 AM
