Old 10-07-2019, 04:58 PM
Motorman_55792 Motorman_55792 is offline
Default Power valve operation RPM
Does anyone have any information on what RPM the power valve operates on our bikes? Mine is a 2018 xc250 specifically, but I would guess the RPM is similar across many models.
Mine is opening way early (about 2500 rpm) even with the adjuster screw all the way tight. I believe the normal operation should be at 5k or more, but this is just educated guess based on other brands and my snowmobile experience which is higher at 6750 rpm. I am going to dig into the side case and see what it looks like and I will update what I find at that time, but knowing what rpm to shoot for would be helpful.
Old 10-08-2019, 03:17 AM
Gasser Nate's Avatar
How are you measuring engine rpm? Guessing is not really going to be accurate obviously. What sort of engine are you comparing the gasser to? They probably do not have the same characteristics so not really comparable. What is the bike actually doing wrong?
Old 10-08-2019, 12:38 PM
I have no low end. It runs like a 125 and way weaker than my 07 GasGas 250 I sold until in the upper part of the power band. I have a great deal of experience on many engines and this is obviously not working right. I used a sonic tachometer to check the operation with the linkage cover behind the pipe removed. I can ride around the big hole in the power, but it isn't good. If I set the adjuster at 2 turns out as recommended you would swear it is a 125, and with the adjuster screwed in tight it is bearable, but not right. Try setting your adjuster to about 6 turns out and it may run like mine.
Old 10-09-2019, 02:59 AM
Pygmygod Pygmygod is offline
How old is the exhaust packing?
Do your exhaust o-rings leak/damaged?
Stock pipe or aftermarket?
Old 10-09-2019, 09:04 AM
This is a 2018 with low hours. Packing is good. Stock xc fmf pipe and also same with fmf fatty. O rings seal well. I have it jetted perfectly and have also added an RK Tek head since the stock head is very poorly set up. That added enough power to make it ok, but it still is not right.
This is absolutely a power valve function issue. I can't believe I haven't found any manual that states what rpm the valve should start to open or fully open!
Old 10-09-2019, 11:56 AM
gasgasman's Avatar
Maybe the power valve flap is not "timed" correctly.
Is the flap fully closed with the engine off?
Old 10-09-2019, 09:18 PM
I did verify that. It closes fully at idle and opens fully when reved up. Good idea, though.
Old 10-10-2019, 12:33 AM
(F5)'s Avatar
(F5) (F5) is offline
With a centrifical governor it should progressively open to some extent. The addition of a spring adjustment will just add preload. Haven't pulled a later unit apart.
I'm guessing snowmobiles are pneumatic, from my tiny experience there they tend to open rapidly depending on pressure bleed, at least on my Cheetah engine that was the case until I converted it to servo motor.
First check for free play, if there's heaps airflow can open the valve. Then check all the balls and correct spring arrangement.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 10-10-2019, 04:44 AM
Probably because there is not any adjustments to correct if it is out of spec.
Have you checked ignition timing? If the key way is not aligned properly or sheared etc it will affect power.
Sorry I can not be more help but the gassy power valves are so simple they rarely go wrong. The only thing I have seen the early ones do was break off the small stud on the power valve plate.
Old 07-20-2020, 10:21 PM
Been a long time coming, but I finally took the side cover off and found the problem. The pin that the power valve adjuster screw pushes against was only 1/2 way in the shaft. The case must have held it from coming out completely. Now it runs like it should.
Power valve viper77765 Enduro Engine - 2 stroke 11 03-11-2019 09:56 AM
Ec 300 power valve Jonisaacson17 Enduro Engine - 2 stroke 11 07-18-2016 09:01 PM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
power valve nut bonkeye Enduro Engine - 2 stroke 4 10-11-2012 06:40 PM
Checking for proper power valve operation 2003 EC250 SideshowBob Enduro Engine - 2 stroke 4 04-08-2010 01:00 PM
