Old 12-10-2019, 06:03 PM
Adam500 Adam500 is offline
Default 2000 XC300 with ohlins questions...
I just picked up a basket case 2000 XC300. Doing my best to bring it back to life this winter.
It has upper and lower triple clamps from what I believe to be a 2000 CR250.
it has ohlins forks. An Exel rim with AJP hub and Nissin master and brake caliper.
The caliper mount has been "modified" ugh... to fit the ohlins fork.
WTF do I have??
Are the wheels and brake gas gas or Honda?
I know pics would be great here and I'm working on it.
Old 12-11-2019, 03:31 AM
RBrider's Avatar
RBrider RBrider is offline
WTF do I have??
My '01 XC 200 has AJP hubs & Hyd clutch. Nissan brakes same as '01 Honda CR 250, but front & rear disc are same as '01 KTM. The Excel rim is probably aftermarket as my '01 GG has DID rims. Forks are WP, but shock is Ohlins.
Sounds like a junkyard special but it all works, in total, very well. Yours will too once you get it sorted out.
RB
Old 12-11-2019, 11:42 AM
jostby jostby is offline
I'm not sure about the hub but everything for the brakes sounds like GG. There was a Dealer Edition (I think it was called) somewhere around '01-'04 that came with Ohlins front. The WP43 clamps and Ohlins forks would interchange. Sounds like somebody tried to do the swap with Honda Forks maybe?
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 12-11-2019, 12:11 PM
cbutler's Avatar
cbutler cbutler is online now
It is correct. AJP hub and excel rim some 01-04 bikes came with DID U wheels.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 12-11-2019, 05:54 PM
Thanks for the response guys!
So if need to replace front wheel bearings and brake pads I get gaser parts or Honda? Caliper needs a full rebuild. Honda or gasser?
I'm sending the forks to Factory Connection. I'll let them identify them and sort them out.... Same with the shock.
I plan on adding steering stops on the frame to mate with the CR250 lower clamp.
right now the stops are the radiator...……..
Old 12-13-2019, 11:42 AM
rvktm rvktm is offline
iv got a set of oc ohlins 46 mm forks of a tm 125 they use a Italian husky calliper bracket brembo calliper there are two types of 46 ohlins one with a base valve the other has popit base valve . the popit type are not that good
Old 01-23-2020, 06:59 PM
turns out the forks came off a Cannondale 440. Sent them and the stock ohlins rear shock to Factory Connection and they are sorting them out. I hope to get them back soon.
Fabricated proper steering stops to match the lower CR triple clamp. Hope it is improvement over the stock forks.
restoring a 2000 XC300 Adam500 Enduro Chassis & Body 12 12-19-2019 06:56 PM
2000 xc300 Jeremyxc300 Used Bikes 1 03-17-2014 06:37 PM
2000 Ohlins shock spring help nknudsen Enduro Suspension 20 04-25-2013 01:42 PM
2000 wp/marzochi/ohlins/sachs/etc. etc mikevancapel Enduro Suspension 8 01-01-2012 08:21 AM
