Old 02-12-2020, 12:58 PM
Nicktamps Nicktamps is offline
Default Clutch howl?
Hi all. Onto my next issue. When the bikes been ridden sometimes I get clutch howl. Usually when on climbs and hard stuff. What things can I do to reduce this?
Cheers
Nick
Old 02-12-2020, 01:24 PM
Neil E. Neil E. is offline
Change to a lower gear so you don't need to slip the clutch.
2011 EC250E
Old 02-12-2020, 02:15 PM
gasgasman's Avatar
Or, install a Rekluse manual clutch.
Old 02-12-2020, 02:44 PM
Don't want a recluse clutch. Don't like them at all. And I can't use a lower gear usually as I'm in first when it happens the most
Old 02-12-2020, 02:50 PM
gasgasman's Avatar
The Rekluse manual clutch is the same as the stock set up. Just different basket and pressure plate.
Old 02-12-2020, 02:54 PM
Awh right ok. Didnt know that. So why is mine howling then? Just cheap crap is it?
Old 02-12-2020, 03:36 PM
gasgasman's Avatar
Just a characteristic of the bike.
They all do it, doesn't affect the durability at all.
The Rekluse does improve the overall feel of the clutch.
Old 02-13-2020, 02:42 AM
The Rekluse Core Manual Kit doesn't contain the basket. If he wants the basket he needs to order it separately.
Old 02-13-2020, 08:54 AM
gasgasman's Avatar
Correct. I should have said hub.
Thanks.
Old 02-13-2020, 05:54 PM
If it doesn't effect the bike I ain't going to spend the money to be fair. Might buy new springs and plates. But not spending 600
pounds onn a recluse core
Clutch washers like Beta guys use to make light clutch feel Dingo_ed Enduro Engine - 2 stroke 3 11-19-2018 03:15 PM
Auto clutch Install, Rekluse or S3 Clutch Basket? Moto7man General Discussions & Announcements 49 11-24-2013 12:41 AM
Clutch lever doesnt release clutch as soon as motor starts cal_tony Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-19-2012 08:59 AM
front brake howl ec300 2t Enduro Chassis & Body 4 02-12-2007 07:33 AM
