Old 03-18-2020, 12:54 AM
TGM_OFFROAD TGM_OFFROAD is offline
Default Spark plug insulator around electrode broke off in the motor
Twice now in a short amount of time I have had the porcelain insulator break off and wreck my top end. Both times were with an NGK iridium plug. Any idea what is causing this? Or has anyone heard of this happening to them? Both instances were with different heads. First the s3 with the high high compression head and second time with an RK tek head. Squish is right around 1.2 on both.
https://youtu.be/_I4NOqaBD_g
Old 03-18-2020, 02:18 AM
hannesd hannesd is offline
if you've had it before, why didn't you check this time instead of keep riding (back home)? maybe you could have changed spark plug and if you have some tools, quick take the exhaust off and take the bits out?
Old 03-18-2020, 03:07 AM
Gasser Nate's Avatar
Possibly a shitty spark plug socket.
Old 03-18-2020, 05:06 AM
I can imagine that a socket brakes the insulator above the hexagon, but his porcelain was broken around the electrode.
My personal opinion is, that the engine suffers from detonation. He has several riding videos on YT and I always have the impression that something sounds weird. Detonation can kill spark plugs...
The engine sounds strange in this video too. Long before the plug failed....
Old 03-18-2020, 07:08 AM
Yes I was just riding it back to my truck. I carry tools with me but nothing to take the springs off my expansion chamber
Old 03-18-2020, 10:55 AM
i thought the same... first i was thinking big end or cranck bearings ...
Old 03-18-2020, 01:12 PM
I am not sure why I am getting detonation. The RK tek head should not be raising the compression ratio that much. I am already running 101 octane fuel. The jetting did seem to have a little lean spot around 1/3 throttle. I will do a pressure test once it is rebuilt to search for a potential air leak.
The jetting I was running at the time was
48 pilot
A/S 1.0
NECH needle on the 5th position ( I bought two needles that are richer on the suzuki chart in hopes I can richen the mixture but keep the same power delivery, I really liked the smoothness of the NECH)
170 main, the main doesnt seem to be an issue since when I go wide open it is fine, the issue seems to be 1/3 to 3/4 throttle at high rpm where I get the lean spot.
Engine mods are
RK Tek head 13.5 to 1 is the supposed ratio per the stamp on the head insert / S3 racing cylinder / House of horsepower exhaust
timing is not adjustable so I don't know how that could be a factor
When I rebuild I am going to back to the GP head that came on the bike when I bought it.
Old 03-18-2020, 04:13 PM
SS109's Avatar
SS109 SS109 is offline
Yeah, the engine doesn't sound right in that video. Sounds lean to me. I would definitely be checking for air leaks. Make sure the exhaust pipe is sealed up well to the cylinder as air can be introduced there as well.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 03-18-2020, 06:21 PM
I have seen them fracture the porcelain all the way through. To be honest I didn?t even watch the video yet, just a quick comment before I went to sleep! 😆
Old 03-19-2020, 03:56 AM
gg3's Avatar
gg3 gg3 is offline
Bit of a mystery?
48 pilot- Rich
A/S 1.0-Rich
NECH needle on the 5th position- Rich
170 main-ok
Sounds real lean.It should have eaten that hill climb with ease.
Agree with ss109,air leak or really low float level?
Sorry no help really.
Spark plug eviljim Enduro Engine - 2 stroke 4 01-06-2013 02:35 PM
spark plug help ec 125 rmlt2008 Enduro Electrical & Wiring 5 09-16-2011 11:35 PM
Spark plug? Pepperami Enduro Engine - 2 stroke 3 06-28-2011 01:49 PM
Spark plug gasgas125sm08 Enduro Engine - 2 stroke 0 03-08-2010 09:42 AM
Spark plug gap???? Bandit9 Enduro Engine - 2 stroke 1 08-29-2007 05:26 PM
