Old 08-19-2020, 03:55 AM
Default Something I haven't read about yet. Clutch issues...
Of course I have read about clutch issues, especially about dragging issues and after one of my Gassers did it so vigorously that I had to sell it I thought I am done with all thousand things I tried.
But, after reading in a British forum that someone altered his clutch master cylinder and was able to increase bore size I have an idea I'd like to try. Especially because my low hour 2019 EC 300 started to get the dragging issue when engine is hot. First appeared after about 20 hours and when ambient temps were in the 90's.
My system is perfectly bled, I change gear oil exactly every 20 hours or earlier using Bel Ray Gearsaver 80 as this reduced clutch squeal quite a bit.
However, all the ideas of longer clutch rod and washers underneath the throwout bearing etc. can not work as a longer rod or a thicker washer will not alter the lift on the pressure plate.
But a bigger master cylinder, pushing the slaves piston further out would. Hence I am interested if there is a bigger Magura master than the standard one (9.5 mm diameter). Maybe one from a different brand like KTM or Sherco. While I know the diameter of the GG master I have no clue what bigger diameters would be available from Magura. Convert to a brake oil based system is possible too but I do not know if there is a different slave that would fit...
I'd appreciate your thoughts...
Old 08-19-2020, 10:36 AM
gasgasman's Avatar
A trick back in the day was to use a valve adjusting shim to add length to the clutch push rod.
On the clutch master cylinder. You will need a longer stroke to increase the slave cylinder stroke.
Old 08-21-2020, 12:49 AM
Adding shims or even using a longer rod (I tried three different lenght on my former bike) will not change anything. The shim or rod will just push the slave piston back in its housing. It won't add lift.
I talked to a German dealer and he said he has brake fluid resistant o-rings for the slave. So I could change the Magura for a 10 or 10.5 mm Brembo clutch master. I am hesitating because I fear that the clutch pull will be even harder.
Old 08-21-2020, 03:00 AM
Anders's Avatar
Anders Anders is offline
There are also Magura 10.5mm masters available, e.g part number 2700185
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 08-21-2020, 01:32 PM
Cool!
Thanks mate
Old 08-21-2020, 02:23 PM
gasgasman's Avatar
You can't compress a liquid.
The motion applied at the master cylinder, will transfer to the slave cylinder.
Your master cylinder maybe bleeding off internally.
Old 08-22-2020, 05:55 PM
I think Doc means like when you throw fresh brake pads in.
The difference is offset by the fluid level rising in the master. The change at the pedal or lever remains the same.
Old 08-23-2020, 02:11 AM
You can take off the slave cylinder and push the piston back in its housing easily and that is exactly what happens when you install a shim or a longer rod and that is why this trick never has worked and never will.
Old 08-23-2020, 03:49 AM
Gasser Nate's Avatar
My 2018 is oil based. Is yours not?
Old 08-27-2020, 11:44 AM
If you ask me, mine is oil based. I don't get what's behind the question to be honest
Clutch issues when warm ian1987 Enduro Engine - 2 stroke 3 05-17-2021 11:09 AM
Clutch issues EC250 Enduro Engine - 2 stroke 6 06-20-2016 08:26 AM
Clutch issues Trigga Enduro Engine - 2 stroke 3 09-08-2014 02:23 PM
2012 Ec250 Clutch issues... Novascotiarider Enduro Engine - 2 stroke 9 05-07-2013 12:50 PM
Hydraulic clutch bleed "read this" moto9 Enduro Chassis & Body 5 10-11-2011 10:48 PM
