Old 12-10-2020, 01:47 AM
kasparsL kasparsL is offline
Default FSE450 2005 crank case brether
Hello, I hope to get some information from knowledgeable users. crankshaft breathing tube makes strange noises "flushing toilet" when engine is turning, but not when running. And also leaks oin when in high revs. Is there problem with the piston rings?
the bike starts fine, runs great, no knocking noise, only the pressure in case
you can hear the sound when i turn engine and stop. in this video
https://youtu.be/aQwoOvgYG1I
Old 12-10-2020, 08:37 PM
Gasser Nate's Avatar
There was a recall/modified breather tube when they were new. I don?t have the info on it anymore though. I would get a leak down test done to see the condition of the rings and go from there.
Crank Case Breather Hose Question Doc Brown Enduro Engine - 2 stroke 6 06-05-2020 09:37 AM
Crank case breather/ Oil in intake spencergt66 Enduro Engine 4 stroke (including EFI & Exhaust) 1 06-10-2016 11:39 AM
2005 EC250 in WI cracked engine case - $600 offer 3hunerd Used Bikes 3 03-24-2014 06:56 PM
Crank case interchangability Rabbitist Enduro Engine - 2 stroke 5 09-21-2011 05:44 AM
Crank bearing spinning in case... CDBiker220 Enduro Engine - 2 stroke 8 02-16-2011 11:53 AM
