Old 03-17-2024, 09:46 PM
dode dode is offline
Default Uk transmission oil
As the title says what are the uk lads using for transmission oil as a lot of the ones recommended on here aren’t as easy to source I’ve found?
I’ve just changed to Motul Transoil Mineral 10w-30.
The manual for my 2008 EC 250 says 10w30 also but everyone else on here uses all sorts of weird and wonderful things other than what the manual states haha.
Cheers.
Old 03-18-2024, 01:40 PM
(F5)'s Avatar
(F5) (F5) is online now
There's two Transoils. Hopefully they haven't changed packaging again. Mine dragged on std stuff, but was sweet on 'Expert' I've used that ever since on my 07.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 03-18-2024, 02:10 PM
Crap!
I’ve put the standard stuff in as it was 10w 30 and the expert is a 10w 40…..
Wasn’t too sure if the expert was on or not as the manual stated 10w 30.
Old 03-18-2024, 03:12 PM
you should be able to find belray gearsaver in the uk
2003 txt250 Pro
2013 Ossa 280i
Old 03-19-2024, 01:16 AM
(F5)'s Avatar
It shifted nice on the std stuff but you couldn't kick start it in gear without really spinning it.
The expert stuff you could just pull the clutch in and prod. If it is working OK then fine. If it isn't then a change should help. An 06 may have quite a worn basket and hub, but cross that bridge if it comes up.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Transmission bearing Kaliz Enduro Engine - 2 stroke 1 10-07-2015 06:32 PM
Transmission ec 300 gumby "Wanted to Buy" & "Want To Trade" 10 11-02-2014 09:52 PM
Help with stuck transmission Zhack Enduro Engine - 2 stroke 6 07-05-2011 07:49 PM
ec 300 transmission oil jetfish Enduro Engine - 2 stroke 32 10-27-2010 05:00 AM
No oil in Transmission RPB111 Enduro Engine - 2 stroke 5 03-17-2007 08:49 AM
