Old 05-30-2008, 10:20 AM
super_rat super_rat is offline
Default 2007 EC 300 Speedo
Does the factory GG speedo for a 2007 EC 300 run on AC or DC? Does it use a battery? (referring to a battery in the speedo, not a bike battery)
Thanks
Old 05-30-2008, 10:32 AM
eff's Avatar
eff eff is offline
Is that the TrialTech version? If so, it runs on AC or DC and has an internal CR2032 battery as well.
2004 GasGas DE250
Old 06-01-2008, 01:33 PM
Default Speedo pics
I don't know who makes it. Here are pics of front and back. A label with "BE250634005" is on the back. "Made in Taiwan", "10R-022812" and E13 are cast into the plastic on the back.
If this is the Trialtech speedo, where does the battery go?
Any ideas where to find a manual?
Old 06-01-2008, 01:48 PM
Default Speed manufacturer
Found it. Googling 10R-022812 took me here. http://www.acewell-meter.com/images/V1manual.pdf
Manual is at: http://www.acewell-meter.com/images/V1manual.pdf
It's an Acewell ACE 39xx computer
Seems to run on 12VDC.
Anybody have a document that describes the inputs? Nothing in the "manual".
Old 06-02-2008, 01:03 AM
armyoforange's Avatar
armyoforange armyoforange is offline
the red&white wire is for power i have mine hoocked up to a 9 volt battery i had it hoocked up to the ignition but it surged like your headlight does i have the 30 watt ignition or 2k2 i think the green and black wire is for your speedometer you should have gotten a 4or 5 foot leed that threades into your front brake caliper bottom and a pickup attatched to your hub the yellow wire is for your tack it ataches to the coil where the spark plug wire boot comes out of cant remember whitch one once i got every thing else runing i just touched the wire to the diferent conections until it worker sorrey for the bad spelling done didnt finish high school hope this helps ihad to do the same with my bike figure it out
James 00 ktm exc 300
07 ec 300
Old 06-06-2008, 10:47 AM
Default Speedo schematic
Victory!! I got a PDF file from ACEWELL that shows the connections for the 2007 GG speedo. Let me know if anyone needs it.
Old 06-06-2008, 05:38 PM
Ud_luz's Avatar
Ud_luz Ud_luz is offline
Would you email it to: deltron@swbell.net
Thanks, Bill.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300
Old 06-22-2008, 06:42 PM
Default Speedo now working
Finally got the GG/Acewell speedo set up. The Acewell pinout document shows that it had to run on DC so I had to get 12v DC on the bike. Bought a TrailTech rectifier/voltage regular (7003-RR150 ) and capacitor (040-CAP56) and a 10 amp fuse. By the way, if I were doing this again I'd get the smaller capacitor (040-CAP27). The CAP56 is HUGE. I got AC from the white coil wire I found taped up in front of the tank. The yellow lighting coil wire that would run the lights (if it had them) on the bike was left untouched. Everything works great. The capacitor even runs the speedo for about 5 minutes after shut down, letting you do set up with the engine off. The Acewell requires an external 9v battery for the clock so I also wired that up.
The speedo provides MPH, RPM, trip 1 odometer, trip 2 odometer, odometer, max RPM, max MPH, average MPH, clock, total time, run time, shift light.
Mounted on rubber with nylon bolts. Red circle is tach pickup.
Made a wire loom with 4 positive and 4 negative terminals. May want to run a GPS.
Finished install. Note 9v battery upper right.
Old 06-26-2008, 06:32 PM
slocalspode's Avatar
slocalspode slocalspode is offline
Super Rat wrote:
"Victory!! I got a PDF file from ACEWELL that shows the connections for the
2007 GG speedo. Let me know if anyone needs it."
I would be very interested to get a copy of the .pdf showing the connections
for the Acewell computer. I went to their web site and only found the users
manual. Nothing showing the color coding or what connectors feed what
information to the computer.
I picked up a used "take off" from an 07 TXT and it is missing the tach and
temp sensor wire connectors.
That and I don't know which wire to feed it 12VDC to get the clock and
LCD back lighting to work.
I would appreciate it very much if you could send it by PM here or send
it to my earthlink acct. jjwallace@earthlink.net it will bounce with a spam
message because you are not in my address book. Ignore the warning.
Thank you, Jeff So-Cal.
Old 06-27-2008, 07:14 AM
cdn280 cdn280 is offline
Good god man that capacitor is HUGE! Who told you to use that? It probably holds enough current to do some arc welding ! Looks like something from a 1960 tv set. I'm sure something the size of the tip of your finger would have worked, plus I don't think you needed DC, although it would be nice for the gps power.
The same unit works on my 2006 and don't think there is any dc in the system. I'll have to hook up the 9V battery though so the clock doesn't reset every time.
EC300 2007 speedo darren Enduro Electrical & Wiring 3 07-15-2010 12:28 PM
ec 250 speedo help gregtenerife Enduro Electrical & Wiring 3 06-17-2010 01:06 PM
Harvest Classic 2007 European & Vintage Motorcycle Rally October 19 & 20, 2007 sanderjavant Republic of Texas 1 09-26-2007 05:18 PM
EC 300 speedo ?? oldgoat Enduro Electrical & Wiring 7 08-11-2007 03:29 AM
