Will a YZ250 front pipe crossover to a GG EC250 ?
Hi,
I have found a used DOMA pipe from a YZ250 it says it will fit a 02-09 YZ im just woundering would it maybee fit my 01 GG 250, as i have seen before FMF gnarly's from GG's been fitted onto YZ's! Thanks Dhyllan
2001 Gas Gas EC250 Supermoto Boyesen Pro Series Reeds, Messico & Modified FMF TC II, Black Powdercoated Wheels & Hubs, Red Renthal Fatbars, Polisport Handguards, 4 POT Brembo Front Brake W/ Floating Rotor Want: Doma,Messico Or 06 GG Front Pipe, RB Carb & Head Mod, DE250, XC250 Or EC200 CDI (If you have any of these parts PM me!) |
PLease try and report back.
I have two yz pipes sitting here from 2000 and newer and they will not fit the GG.
99 EC 300 |
I have to say that I haven't updated the crossover parts list in a long, long time because "fitting" is "in the eye of the beholder..."
jeff |
I guess i should have said that it was not a direct bolt on!!, but if you have a welder all you would have to do is change the front pipe inlet, and the mounts, and then it would fit.
I thought about doing it with one of these because the stock yz pipes are much stronger than the GG pipes and will take more abuse, i have installed a yz silencer on my GG before, without too much hassle.
99 EC 300 |
Thats not exactly what I would call a crossover part! FWIW, the OEM GG pipes are very stout, like an FMF Gnarly.
On the 125 GG, A YZ 125 pipe will bolt up. |
Thanks guys i will definatley try as it is cheap ! and report back, i have also found a doma pipe off a 2002 CR250, i know a few parts crossover with the CR what about the front pipe? anyone any expierence? Also if use pipes off other bikes on my GG will perform just as well if i got a pipe made for the GG perofrmance wise will there be a difference as i dont know if doma would change the characteristics of each pipe for specific bikes? thanks
I thought I saw where an 01 RM 250 pipe was the same as a gasser, and I must say they look the same to me. Don't know about the mounting bolts though, but the pipes look identical.
2008 KTM 300xc Plated |
Come back to this! Which year of the yz pipes will fit the 125 2011gasser?
4 strokes are only good for power generators |
Front brake Assy crossover | gtsnowcrack | Enduro Chassis & Body | 1 | 07-24-2012 09:32 AM |
front brake crossover | kai69 | Enduro Other... | 5 | 09-04-2010 04:47 PM |
Front pipe mounts on ec250 | Gonzo | Enduro Chassis & Body | 3 | 02-24-2007 08:24 PM |
12T front sprocket crossover part | Leon_gasgas | Enduro Engine - 2 stroke | 4 | 12-01-2006 02:11 AM |
