Old 03-03-2009, 04:25 PM
Keg Keg is offline
Default 09 EC300R Fork Compression re-valving
Hi all,
I feel the high speed valving could do with a bit of a tweak. I am 110kgs (242lbs) and have 0.46kg fork springs in it!
Here is what is in it:
26D x .15 (5)
24 x .2
12 x .15
22 x .2
20 x .2
18 x .15
61 x .15
12 x .15
10 x .3
Firstly where do I get 7mm id shims from? I have been die grinding KTM shims so far.
My new stack is:
26D x .15 (3)
24 x .1 (3)
12 x .15
22 x .2
20 x .1
18 x .15
61 x .15
12 x .15
10 x .3
Any suggestions???
EC300 2019 (11 Gassers owned, many more to go)
Old 03-03-2009, 06:11 PM
JRDoz JRDoz is offline
Originally Posted by Keg View Post
Hi all,
26D x .15 (5)
24 x .2
12 x .15
22 x .2
20 x .2
18 x .15
61 x .15
12 x .15
10 x .3
My new stack is:
26D x .15 (3)
24 x .1 (3)
12 x .15
22 x .2
20 x .1
18 x .15
61 x .15
12 x .15
10 x .3
Any suggestions???
Lose a few kilos, worked for me
"It's Nature that Brings out the Madness"
GasGas FSR450 07'
Old 03-04-2009, 01:37 AM
stay_upright's Avatar
stay_upright stay_upright is offline
Suggestions about the shim stack or where to get 7mm shims from? I would have thought Go Fasters would have the shims you need - though didn't look to see if you are in the US.
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 03-04-2009, 02:31 PM
Keg Keg is offline
I did some testing last night and I have actually gone the wrong way I think. I need to increase the compression.
I might chuck out the delta shims, put the 20 x .2 back in and either change the cross over shim to a smaller one or make it a single stage stack instead.
I'm in Melbourne, Australia and have got some shims out of Sydney, but I will get onto go faster about them. Anyone know a contact for paioli on Europe as they are the same shim too.
Old 03-08-2009, 04:45 PM
Keg Keg is offline
Bump! Anyone?
Old 03-09-2009, 02:02 AM
No sorry .
'05 Gas Gas 300
'99 KTM 200
Old 03-09-2009, 03:38 AM
ferguscawley ferguscawley is offline
I believe K-tech suspension inthe UK carry these shims. I have not confirmed this but I was told they do.
Old 03-10-2009, 01:24 AM
moto9's Avatar
moto9 moto9 is offline
I have had good luck with correcting the spring rate for the riders weight and then valving the compression stack lighter... and/or lowering the oil level.
But that's with Showa and KYB, I'll dig into the fork and shock when I get the new bike.
The heavier spring gets the bike to ride higher in the stroke and I find it plusher there, then control the action with the valving.
I wonder how adding some float or free bleed would work, I ride tight greasy rooted jungle trails...I added some free bleed to the base valve and I like the results, not sure it would even work on the Marz
Old 03-17-2009, 03:04 PM
snaissidis snaissidis is offline
Hi Guys,
I Just Bought Myself A New Ec 300 09 And Could Use Some Help With The Rear Suspension. Would It Be Easy To Give Me The Standard Settings For It As The User Manual Is A Little Confusing???
Thanx
Old 03-29-2009, 07:08 PM
Keg Keg is offline
I have just done fork seals so now I know the specs for these forks. I may as well post them here so I remember them for next time.
Oil: 5wt
Air Gap: 100mm (I changed it to 110mm and the fork feels plusher)
Fork Seals: 48 x 58 x 9.3/11.0 (I used KTM 48mm seals 48x58x9.5/10.3)
Dust Seals 48 x 58 (Yammie or KTM 48mm)
08 EC300 Fork valving AdrenalineJunky Enduro Suspension 9 08-13-2010 03:58 AM
2010 Sachs fork factory compression stack specs(ec300) bergerhag Enduro Suspension 9 07-01-2010 11:18 PM
Sach Boge 48mm fork info (09 EC300R)??? Keg Enduro Suspension 9 10-13-2008 04:57 AM
2007 Ohlins fork EC250 valving Leon_gasgas Enduro Suspension 12 02-01-2008 03:07 AM
Ohlins 46mm valving for use with spiked tire Leon_gasgas Enduro Suspension 1 03-27-2007 05:16 AM
