Old 04-10-2009, 05:15 PM
alexpp alexpp is offline
Unhappy PowerValve Issue- Take A look at this Picture
I cleaned up my powervalve and after I reassembly everything this is how it looks like:
Doesnt seem right, it looks like it will be open halfway even at idle.
Did I screw up somewhere?
i love my gazuly ...06 ec 300
Old 04-11-2009, 12:58 AM
iancp5's Avatar
iancp5 iancp5 is offline
You've connected it correctly. I can't remember exactly what angle it sat at. It doesn't have to move much - look up the exhaust port and move it to see how much it has to move to fully open then start the bike and check it moves that amount when revved. Thought there was a small washer under the nut though.
Old 04-11-2009, 06:14 AM
eff's Avatar
eff eff is offline
I don't remember where mine was when I had it apart. The workshop manual photo suggests that it should be rotated counter-clockwise until the lower tab rotates to the retaining screw, or until the bend in the actuating rod is near the bottom of the cavity.
2004 GasGas DE250
Old 04-11-2009, 07:02 AM
ramcclure200's Avatar
ramcclure200 ramcclure200 is offline
here is a picture of mine, sows washer also.
http://picasaweb.google.com/ramcclure/2006_07_16#
Old 04-11-2009, 09:01 AM
enstanka enstanka is offline
The PV shaft is "half moon shaped", and fit in a coresponding half moon in the
bracket that is held in place by the allen screw.
Undo the screw and look carefully and you will see what I mean.
Turn the PV shaft and poke a finger in the exhaust port so you will feel when the PV is closed, that will be the position you are looking for.
NOTICE, the PV shaft can rotat as many turns as you want, and during a 360 deg turn there will be two closed points. Only one is the correct one when the half moon cut out line up with the PV acuator bracket/washer.
I did this myself two day ago, hope this helps.
Old 04-11-2009, 11:58 AM
When bike is not running and you pull power valve, so it's open. Than will it go back to closed position by itself? Mine seems to stuck in the middle.
Old 04-11-2009, 01:40 PM
iancp5's Avatar
You haven't said why you are convinced it's half open? so what everyone is therefore saying is we can't remember the angle it sits in the relaxed position so look up the port or feel up there and check if it's fully down. But looking at those other photos does suggest yours is stuck! Best to be 100% certain. If it is stuck take the actuating arm off and check the PV rotates freely if that's ok it must be the centrifugal end. Apparently sometimes balls get jammed.
Old 04-11-2009, 01:58 PM
Let me try and explain it better.
That metal rod that pushes the whole powervalve mechanism will rest at this same spot even if I remove the nut that holds it in place. Basically I believe the problem is down, behind the right engine case cover (IS THERE A WAY TO ADJUST THE ROD THERE?)
iancp5- with regard to how the stopper should sit at rest.... ramcclure200 posted a good picture showing how it SHOULD be (this is how I remember it being when I took it apart)
ramcclure200 picture of how it SHOULD be
Old 04-11-2009, 02:18 PM
GMP's Avatar
GMP GMP is offline
What you did by pulling on the rod was move the governer and a ball dislodged from its ramp, jaming the governer. You now have to remove the side cover to fix it.
Old 04-11-2009, 04:03 PM
Ok... so I removed the side cover, what do I do next?
Which part were you talking about?
PS: Thanks for helping me out here
Did I broke something in that picture? GasTimppa Pictures & Videos 7 02-20-2010 03:46 AM
clutch issue boostedte37 General Discussions & Announcements 2 11-09-2009 06:58 PM
2K2 Picture cladoo Enduro Electrical & Wiring 10 04-16-2008 10:01 PM
Nice Picture! Mark Berg - CPD General Discussions & Announcements 3 04-02-2008 08:21 PM
GasGasRider.Org Fender Picture Boomhauer General Discussions & Announcements 11 08-11-2007 08:08 PM
