Old 05-22-2009, 07:30 PM
mxdj2003 mxdj2003 is offline
Default clutch plates
does anybody know what the thickness of the Gasgas friction plates are? i just bought a cr 250 basket case , and long story short i took one of the clutch plates and matched it up with the Gasagas plate and it was perfect, but i would like to know the thickness of the Gasser plate so i can measure the 2 before i order a set, if it works it will save a little bit on clutch plates, i priced a set of Cr plates at$ 60.00 verues the Gasser plates at $ 125.00
Old 10-19-2009, 12:19 PM
stainlesscycle's Avatar
friction disc:
2.75 to 2.85 mm
wear limit: 2.68 mm
drive plates:
1.45 to 1.55 mm
Limit: 1.40 mm
which year cr250 was it? i'd love to buy some friction plates for cheap..
was that a honda cr250 or a husky cr250??
Old 10-19-2009, 01:03 PM
i found this info:
2001 (honda) cr250 Clutch Disk(s)..............2.85mm (0.112in) - service limit.
assuming stock cr250 new plates at 2.95mm-ish (or more..)*7 = .7mm too tall of a stack... i'm also assuming new gasgas plates at 2.85mm... i guess you could use 50/50 stock/cr and get a stack height that would be close enough. but it would probably drag.... are the drive plates the same as gasgas??
Old 10-19-2009, 08:28 PM
Ud_luz's Avatar
Ud_luz Ud_luz is offline
Rekluse has some thinner drive plates than stock.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300
Old 11-02-2009, 01:37 PM
i checked the Barnett website and the Gas Gas part no. is the same as a few of the hondas cb650 and an 81 cr450
broken clutch plates? stainlesscycle Enduro Engine - 2 stroke 24 09-27-2011 04:39 AM
steel clutch plates steve Enduro Engine - 2 stroke 3 03-15-2011 09:22 PM
new clutch drive plates dank Enduro Engine - 2 stroke 4 06-23-2010 11:15 AM
New DP clutch plates won't fit - suggestions? stay_upright Enduro Engine - 2 stroke 6 05-26-2008 09:59 AM
