Enduro Product Reviews Feedback & Comments on Products Tested |
Up-Tite carb filter
Got my Up-Tite carb filter mounted.
I used a 7/8" handle bar clamp ( that's what Home Depot calls it) to mount it to the power valve chamber. It has been very dusty lately and I have been noticing dirt in the float bowl. I plan on riding tomorrow with Sled-Fiend , so I'll remove the filters and inspect them after the ride. |
Jeez, you're gonna get a lot of gawkers asking what that is.
Tell 'em it's a turbo. |
When you drop the bike where does the fuel go ? Does it go through the filter or back into the bowl ? If the bowl, would it be flooded then ?
The idea is not to drop the bike.
The fuel will drain back into the float bowl, an excess will drain out the overflow tube. After a 17 mile ride today, there was dust on the filter. And I had not ridden behind anyone today. |
That's a good idea. If anyone has ridden Land Between the Lakes during dry times, you know you need one. Here in the South, I run my vent hoses back and into the top of the air box. Where yours is routed, we would soon have under water in the many stream crossings.
Link, Mister !!!
What is that plastic thingy with the brass inside to the right of the filter? It kind of looks like a fuel filter for a lawn mower.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300 |
Up-tite carb filter
That is a fuel filter with a 90 degree elbow. I run one, they have been available for awhile now.
Trailrider |
I don't think water crossings are a big concern in Texas at this time, but up here the carb would suck water into the bowl just like stock, but I guess it would be clean water! I just have small individual filters on each line and the carb stays clean. I would need two of those trick parts.
Here is an alternative from 7602 Racing at a reasonable price. A lot of guys on the Husky forum use this one or the UpTite version on the TE610's. I heard good things about both of them. The 7602 version is nice with the extra hose hookups to avoid the T-fittings like in the above pics. Note: their design allows you to run one hose up into the air box. You will see this in the link below (look for center hose).
http://www.7602racing.com/prod_t6cf.php
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
pre-filter | 2stroker | Enduro Intake/Carburetion - 2 stroke | 6 | 04-26-2009 08:56 PM |
Air filter | anathema | Enduro Engine 4 stroke (including EFI & Exhaust) | 16 | 10-29-2008 07:54 PM |
Which air filter for 07 EC | Tom Zelko | General Discussions & Announcements | 9 | 06-29-2007 10:09 AM |
FSE Oil Filter | McGuiver | Enduro Engine 4 stroke (including EFI & Exhaust) | 5 | 05-15-2007 08:49 AM |
which air filter? | speed addic | Enduro Engine - 2 stroke | 9 | 04-16-2007 07:21 AM |
