Old 07-22-2009, 01:57 PM
Dunk's Avatar
Dunk Dunk is offline
Question Powervalve Stuck?
Hello there, I have just bought a 2001 Gasser 250 SM converted to a 300, It's done 2k miles from new and has been dry stored for last 4 years and started monthly.
Just took it up the road pulls well through bottom end, then it's as flat as a witches tit from then onwards, so I'm assuming the powervalve is stuck, new to Gassers so any advice on sorting it would be appreciated
Duncan.
Old 07-22-2009, 02:46 PM
jostby jostby is offline
It's a bit of a pain but you can remove the PV cover on the right side behind the exhaust. Flick the throttle while the engine is running and you can visibly see whether it is opening/closing or not. Be gentle moving the linkage by hand, you can dislodge the roller bearings that actuate it (down inside the case by the clutch), then it will stick for sure.
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 07-22-2009, 03:33 PM
Dunk's Avatar
Problem sorted, bolt on the end of the rod had come loose and fallen out, "censored" me it's fast
Old 07-22-2009, 08:39 PM
slocalspode's Avatar
slocalspode slocalspode is offline
Pictures, we need pictures! I'd love to see another EC250SM.
Here is mine.....sorry If I have posted this link too many times...for the regular
readers.
There is not enough SM exposure around here.....
Jeff So. Cal.
ec250 stuck in gear thelonius General Discussions & Announcements 22 01-10-2010 01:09 PM
swing arm shaft stuck whodat Enduro Chassis & Body 17 03-22-2009 07:53 AM
intermittant stuck throttle jasont1532 Enduro Intake/Carburetion - 2 stroke 6 02-21-2009 06:55 PM
stuck between a ec250/300 blitzem General Discussions & Announcements 9 10-03-2008 10:40 PM
Stuck Throttle? jeffd Pictures & Videos 7 01-24-2007 08:04 AM
