Old 11-02-2009, 06:48 PM
Brian's Avatar
Brian Brian is offline
Default Cyrca Center Reach Mount
http://store.cycraracing.com/ceremo11ba.html
Has any one tried these? Do they mount up ok?
Just bought an 06 EC 250. I think the bars are stock don't see any markings on them.
Old 11-03-2009, 06:17 AM
rpduc rpduc is offline
Yes I have then on my '05 MC 250 and they are solid as hell. MUCH better than the previous clamps that clamped to the tapered part of the bars. I also used the threaded inserts in the bar ends, another excellent product.
http://www.systemtechracing.com/product_p/77-01.htm
They should mount up fine. There is fair amount of latitude on width because the holes on the inboard end are slotted. Plus they can be bent a tad to move that point around if necessary. The only problem you might run into is you need some room between the bar and the fork cap to mount the inner clamps. Maybe 1/2" or so... On my MC I had bar risers in there already so no problem.
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
'07 Duc S2r 1000 still rubber side down...
May be so... May be not so...
My Website
Protec Sub mount kit - are they still around Keg General Discussions & Announcements 1 10-13-2010 07:20 PM
08 top shock mount. nick790 Enduro Suspension 3 03-01-2009 03:46 PM
