Old 12-13-2009, 05:21 PM
carlg carlg is offline
Default 01 EC300 Spark Arrestor
I have an 01 300 with a Doma pipe. currently has a FMF Turbine Core 2 mounted. I was told by the person that I bought it from that it was off a Kawasaki KX-250 as I recall. I'd like to install one of the FMF Q mufflers but see that the earliest application on the FMF site is 2007. So I guess my question would be can you put the Q on an 01 year model, or just stick with what I have? I've seen that one of the threads mention a subframe change around 05 so I suppose the 07 item won't fit. Also someone tried to mount a Kawasaki Q and mentioned that it hit the fender. Any assistance would be appreciated, thanks Carl
Old 12-14-2009, 09:00 AM
webmaster's Avatar
webmaster webmaster is offline
Administrator
Hi Carl,
FYI - Your current silencer is made by fmf specifically for the gasgas.
Have you looked at the db snorkel?
Jeff
Old 12-14-2009, 11:15 AM
That's odd as FMF didn't have an application when I phoned them this morning. I see that GoFasters has both types listed however the Q will only fit 07 and newer. I guess that I will stay with the existing muffler as fitting the Q would probably require surgery or possibly the newer rear subframe if you can go that route. Sounds expensive, thanks for the help!
Old 12-14-2009, 01:06 PM
Nick's Avatar
Nick Nick is offline
An FMF Q from a 99 KX fit the 05-06 with minor modification. Not sure about 03.
Old 12-14-2009, 01:48 PM
webmaster's Avatar
Administrator
The silencer was purchased in '01 when I bought the bike - they may not make it for the specific application any longer.
Old 12-14-2009, 03:58 PM
Eric K Eric K is offline
Here is what I found...
http://www.gasgasrider.org/forum/sho...ighlight=spark
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 12-14-2009, 07:59 PM
Well based on the last post which I had looked at it's pretty clear that the Q muffler won't properly fit on the 01 300. I went ahead and picked up a spare TC2 from GoFasters. It will be interesting to see if the part number is the same as the 99 KX-250. Again thanks for all the help!
End cap with spark arrestor Qui-gon General Discussions & Announcements 3 05-08-2008 04:41 PM
