Old 03-18-2010, 07:05 AM
gasgasquebec's Avatar
gasgasquebec gasgasquebec is offline
Default PV left drain plug
Hi! I'm new to this forum. I think this is my second post. I own a '03 gasgas ec250 and I love it.
Yesterday I was cleaning the left power valve cover and I came across the drain plug (connected on a black rubber tube)just under.
There is a very little hole in the plug...as small as a pilot jet
Should I drill it larger/bigger?
Thanks
Philippe
Old 03-18-2010, 09:43 AM
jostby jostby is offline
I think the hole in my aftermarket PV cover drain is about 1/8". Was it draining like it should? If so I would leave it alone. If it was plugged solid I would drill it a little larger.
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 03-18-2010, 06:34 PM
gasgasman's Avatar
Do not drill it out!
It is a calibrated orfice.
If you drill it out bigger, it will render the power valve chamber useless.
Old 03-19-2010, 03:53 AM
A few drops, sometimes. The drain hole was blocked. I cleaned it.
Thats why I asked...If this hole have someting to do with powervalves configuration I will not drill it
Old 03-19-2010, 06:22 AM
stainlesscycle's Avatar
my pv cover has no drain, just a screw to empty it occasionally - is there a reason for the drain (aside from sludge build up...)
Old 03-19-2010, 07:40 AM
Rick's Avatar
Rick Rick is offline
I remove my cover to cleaqn the PV area. When the cover is off, you can see the bearings and give them a good once over...make sure there not gummed up with "stuff"
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 03-19-2010, 04:51 PM
gasgasman's Avatar
The OEM cover does have a drain. You have to remove the retaining bolt in the lower left side of the cover.
The other drain is in the cylinder with a hose attached to it.
Old 03-20-2010, 05:34 AM
i have a checkmate cover - i assume it's a copy of the ltr cover...
Old 03-20-2010, 06:09 PM
gasgasman's Avatar
Actually, the "drain" at the lower left bolt applies to any PV cover that you are using.
The drain is actually through the threaded bolt hole. There is an opening cast into the cylinder that allows this.
2T drain plug wence Enduro Engine - 2 stroke 0 10-13-2009 04:28 AM
oil drain plug nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-18-2009 07:32 AM
Oil Drain Plug size Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 1 06-22-2008 12:08 PM
Oil drain plug and radiator cap options sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 6 10-04-2007 08:18 PM
Oil Drain Plug MIKEWA Enduro Engine - 2 stroke 4 01-27-2007 06:19 AM
