Old 07-17-2010, 04:28 AM
trxpeter trxpeter is offline
Default 450 Clutch problem
Here's one for you , I have an 04 450 and the clutch drag is not going away no matter what we do. Plates ,springs and basket all OK ,you can hear it working inside when it's all buttoned up . The master has been bled and slave seems to be working fine, and there's more adjustment left at the lever but it only "just about" lets go 2mm from the bars. Is the master rebuildable , because I can only guess that's the problem but it could be wishfull thinking. What do you all think?
Old 07-18-2010, 07:57 AM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
Slipper clutch or not?
06 Gas Gas FSE 450 USA
Old 07-21-2010, 11:00 PM
I'm thinking it's not a slipper.
Old 07-23-2010, 07:50 AM
Crankin04 Crankin04 is offline
I have the same bike and I've had to bleed my clutch like twice a year. Some times it took up to an hour to get ALL of the little bubbles out of the line that were causing drag and what not.
The AJP master cylinder we have is actually pretty nice and a pretty basic setup, but what you also might want to check is if it's leaking at the plunger at the master cylinder. If so, then get a rebuild kit at www.ajpamerica.com
Good luck and let me know what you find out.
Crankin04
04' GG FSE 450
Live Easy, Ride Hard!
Old 09-03-2010, 12:38 AM
Looks like a new slave kit has it sorted , on to the next problem .
Clutch problem sticky? dank General Discussions & Announcements 16 05-26-2010 01:20 PM
also an ongoing clutch problem...... dank Enduro Engine - 2 stroke 2 05-19-2010 01:24 PM
ec300 clutch problem dirtjunky_uk Enduro Engine - 2 stroke 13 02-27-2009 08:08 AM
05 EC250 Clutch Adjustment Problem dozerash General Discussions & Announcements 1 06-09-2008 05:23 AM
450 Clutch problem mike989 Enduro Engine 4 stroke (including EFI & Exhaust) 17 01-02-2008 08:54 AM
