Old 08-24-2010, 07:31 PM
Kurdt Kurdt is offline
Default Headlight Bulb
I don't suppose any of you could do me a favor and take a picture of your headlight bulb properly installed from the backside. I took the bulb out, and now a couple weeks later I can't seem to figure out how the spring that holds it in place, fits in there......... don't ask, It's been a long week.
2010 GasGas EC 300 Nambotin Replica #141
2006 Honda XR650R Supermoto
Old 09-01-2010, 10:23 PM
twowheels's Avatar
These aren't great pictures but they should get you there. I taped the top of the housing in the second shot to attempt to cut down flash glare. The photos were taken from the top.
The screw is at the 9 o'clock position looking at the back of the bulb. The wire comes out from the back, plunging at 12 o'clock and then back out, running above the housing before the tail appears to locate into the housing at about 4 o'clock.
Heading anti-clockwise from the screw, the wire runs straight against the back of the bulb roughly parallel with the ground at the bottom of the bulb. This tail terminates flat against the bulb.
Hope this helps.
Steven Beane #275
afterhourscycle.com
FSE450 bulb vwboomer Enduro Electrical & Wiring 1 04-01-2010 09:01 PM
07 headlight? wence Enduro Electrical & Wiring 4 11-23-2009 12:21 PM
Bulb rating for 2001 ec300 johns2394 Enduro Electrical & Wiring 0 12-02-2008 01:12 PM
Headlight Help loopole Enduro Electrical & Wiring 3 05-28-2008 02:08 PM
