Old 09-21-2010, 07:35 PM
gasgasquebec's Avatar
gasgasquebec gasgasquebec is offline
Default Broken rear shock clevis
Hi everybody!
Just found this tonight on a routine maintenance. The clevis of my '03 Ohlins shock is broken. I'm looking for opinions... Welding? Buy a new part?
I am from Canada Thanks for any inputs.
Phil
'O3 EC250 RED TRACTOR (Rear-trial tire Front-MotoZ Terrapactor)
'89 KDX200 Indestructible (Worn out GG tires )
Old 09-21-2010, 10:08 PM
HydroDog's Avatar
HydroDog HydroDog is offline
Buy a new part.
Welding will never replicate the structural integrity of that part.
07 GG EC 300
05 KTM 250 exc
99 KTM 640 enduro
Old 09-21-2010, 10:27 PM
lankydoug lankydoug is offline
I'd be checking the swingarm and shock link bushings just in case they are worn enough to cause a side load that would have broken your shock. It could have been fatigue and old age but it would suck to put repaired or new shock on and have it do the same thing.
Old 09-22-2010, 04:59 AM
Yeah there was a little play in the botom shock bearing...but all others as still in great shape since they are installed for about a season.
I will buy a new clevis.
Is it hard to replace? Can you tell me please how to replace the clevis? Do I need a special tool or a press? Is is an easy job?
Thanks a lot.
Old 09-27-2010, 02:53 PM
The 2 settings washers was not in place for some unknown reasons so this is the reason for the breakage...The shock is now at a suspension shop for repair and maintenance.
Thanks
Old 09-27-2010, 07:35 PM
twowheels's Avatar
Thanks a lot.
It's a lot easier if you have both ears of the clevis intact
Basically the procedure is to slide a rod through the clevis bolt holes and turn while holding the rod in a vise.
Steven Beane #275
afterhourscycle.com
Rear Shock Spring--Where Am I? Where Do I Go? smstewart Enduro Suspension 0 04-19-2010 05:35 PM
Rear brake clevis Fred1956 Enduro Chassis & Body 12 01-24-2010 02:51 AM
Removing Rear Shock gasIdaho Enduro Suspension 12 02-04-2009 10:45 AM
Broken - Aluminum rear fender support Wellsy Enduro Chassis & Body 6 07-28-2007 10:38 PM
ohlins rear shock broken! tommo Enduro Suspension 4 05-07-2007 07:15 AM
