Hi,
am new to the forum...have recently bought GG EC300 - 2004 model but with very little use. Bl**dy awesome bike compared to the heavy 4T bikes I have been used to. Have just taken delivery of a JD jetting kit from the US. UK GG importers recommend as standard a 38 Pilot, 178 Main and N1EF needle on clip position 2 or 3. JD jetting recommend Blue needle, CP 3, 185 main jet if running below 55 degrees F (!!) 182 main above 55 degrees, pilot 42 or 45. Wondered if anyone else was running the kit in the Uk and if so what settings they use. Likely to be running the bike to 2500 feet elevation max and over winter so below 55 degrees seems about right. Having looked in the jetting database there are very few people running jet sizes as large as 185, but then no one has listed a JD needle either. Dave H |
Do a search in the jetting database. I've been running the JD Blue needle (generic PWK 38 kit) in my 250 since it was new with outstanding results. I have no experience jetting a 300 with it though. Those #s sound rich to me. Since I'm running a 180 main and 48 pilot in a 250 with a #7 slide @ 1000' I would start with a 175 - 178 in a 300 with a smaller pilot.
my 300 use jdjetting with very good results . With main 182 blue needle at 4 clip of the top pilot 42 air screw 1,5 turn out
GasGas EC 300 2004 |
Yep...did to me too. Thats the main reason for the post....seems a hell of a jump up over stock but I have no experience of the JD needles.
Jet settings in the instructions are also the same for all models from 200 - 300cc ??. Seems odd though for JD to put R&D time into a kit and market it with hooky instructions ...do I go with them or not, thats the question. ![]() ![]() Think I may try the #182 main first (as per Gasgasogeros post) and go with the rest of the recommended settings DH |
FWIW
There seems to be an unusual amount of variation between succesful jetting especially between US and UK. There are various theories why. I suspect that the majority in UK need tight, technical settings where the majority in US need more open, fast setups. But that is both a generalisation and theory not fact. There may also be issues with fuel differences between our countries. I tried the LTR setup and it made my 300 run like a dog in the woods. My best setup was using a CCK needle, 42P & 180M. May have some of that wrong but it was definitely CCK needle - smoothest power delivery. You can jet them to be more explosive if you want. |
![]() Quote:
![]() Last edited by DaveH; 11-03-2010 at 07:23 AM. Reason: typo |
Another thing to consider is the "JD Blue" needle definition itself. There are many different JD Blue needles. I'm going through this now with my brother's Husky 250 with a PWK 38 swap. The needle I use is from a kit that used to be called the "PWK38-39 MX/Enduro generic kit". Now it is specified for a KTM 144SX. I told him to contact JD and have him clarify it is the same needle. From my experience JD has always suggested that you start rich and work leaner which is a good conservative plan. Sometimes the starting points are a lot farther off than others. That said, the jump over stock main size is primarily due to the fact that the JD needle, like the D and C series single tapers, has a much wider tip and obstructs the nozzle more at full throttle. Standard practice is one or two sizes up over stock. Countering that, 300s have a bigger signature, so compared to a 250 in the same conditions running the same needle I would expect the results to be one to two main sizes leaner.
FWIW here in the north east USA we ride very tight and technical terrain, and for the most part use very little of a 250s power. Our bikes have to be jetted clean off the bottom as well. |
Thanks Glen...bit new to this 2 stroke tuning lark so not quite sure what you mean by 'bigger signature'. Seems illogical that a bigger engine should need a smaller main but I bow to your experience...
A lot of nadgery technical stuff round here too so I need the low down grunt !
Dave H BMW R1150GS ![]() Moto Morini 1200 Corsaro ![]() BMW R1200S ![]() GasGas EC300 ![]() |
![]() Quote:
![]() Quote:
where to go from here. jetting q. | dank | Enduro Intake/Carburetion - 2 stroke | 105 | 04-11-2011 04:25 PM |
LTR or JD Jetting Kit | Elvis74 | Enduro Intake/Carburetion - 2 stroke | 7 | 04-08-2010 02:49 PM |
Need help jetting an 06 EC 250 | piperpilot12w | Enduro Intake/Carburetion - 2 stroke | 3 | 11-16-2008 11:19 PM |
jetting help for 05 300 please... | mackmack | Enduro Intake/Carburetion - 2 stroke | 5 | 09-03-2007 05:10 PM |
06 300 jetting | fury1 | Enduro Intake/Carburetion - 2 stroke | 1 | 07-31-2007 06:37 AM |
