Old 11-26-2010, 05:38 AM
blanc blanc is offline
Default Running In/First Service Procedure?
Hi All
I picked up a new old model ec200. I have now put four hours on it(Approx). One hour and 30 break in plus a hare and hound. I have never had a new bike before. What should I do to it for its first service? I have replaced the gearbox oil and filter.
What things should I check/grease etc?
Old 11-26-2010, 06:56 AM
swazi_matt swazi_matt is online now
yes do a full service - oil, air filter (possibly) plug, especially if you need to sort out your jetting - sort out jetting if you more than sea level.
Then go through all the bolts to make sure that everything is tight (my kick start lever almost fell off on the second ride!)
You can also go through things looking at grease, I started and was pleasantly surprised that there was grease where it was supposed to be!
Enjoy the new bike ... you will now never want to buy second hand again!
2003 txt250 Pro
2013 Ossa 280i
Old 11-26-2010, 07:01 AM
I cant get over how used a NEW bike looks after its first ride, Im never buying new again.Lol . Its first race was an extreme mud infested hare and hound (I crashed a lot). What about greasing linkages, swingarm etc?
Old 11-26-2010, 07:15 AM
I know the feeling - second ride - dented headder pipe, third ride i snapped off the gear pedal and those black swingarms do not like rocks.
So my recommendation to you is P3 exhaust guard, hyde skidplate, swingarm guards and front disk protector ... that is if you ride lots of sharp pointy rocks
I think the feeling of getting on a spanking new bike far outweighs the tears that come with the first scratches!
2003 txt250 Pro
2013 Ossa 280i
Old 11-26-2010, 08:04 AM
Any recommendations on the swingarm guards and front disk guard?
Old 11-27-2010, 11:44 PM
I would go with hyde swingarm guards and front disk guard www.hydedevelopments.co.za or www.hydedevelopments.com although www.psp-racing.com makes a nice machined guard like the topar ones. the hyde swingarm guards are for the 2009 models, but with a little bit of drilling you can get it to fit nicely, and because they are black they do not spoil the look of the bike
I also forgot to mention a radiator guards a def must I ordered my bike with the guards because i know one silly fall and your radiators could be toast!
2003 txt250 Pro
2013 Ossa 280i
Old 12-06-2010, 04:42 PM
thanks for info. I ordered a carbon pipe guard and crd rad guard. Any good front disc guards?
Old 12-08-2010, 04:03 AM
I use the hyde one, but have just seen a post that mentions that bulletproof designs are now making guards http://bulletproofdesigns.com/gasgasdisk.htm
ok looks like that is rear guards
Hyde works fine for general stuff and as i have never had an issue with the front disk getting damaged i guess it serves the purpose. The hydes do however protect the fork bottoms nicely - these got quite a beating on my last bike!
2003 txt250 Pro
2013 Ossa 280i
Anyone Running Engine Ice? lordfeyr Enduro Other... 14 06-25-2011 10:16 PM
450 run-in procedure fkmf6 Enduro Engine 4 stroke (including EFI & Exhaust) 9 07-03-2010 03:48 AM
Running hot Brian VT Enduro Engine - 2 stroke 9 10-01-2008 07:25 AM
Running rich rustygun Enduro Engine - 2 stroke 4 06-20-2008 04:18 PM
Running In Dingo Enduro Engine - 2 stroke 3 07-26-2007 11:36 PM
