Old 12-10-2010, 10:07 PM
coolum74 coolum74 is offline
Default Resetting cam chain tensioner..how?
Hey all, my trusty 06 FSE has passed the 8000klm mark and has been faultless. Over the last two rides I have noticed it getting noisier and am hoping it's just the cam chain. I just read after searching that someone reset their CCT and it quitened down. Thought it might be worth a shot before I start pulling it apart.
I did a search and couldn't find anything, please don't flame me if I missed it .
Thanks in Advance
Cheers
Adam
2006 FSE450...Gone
2011 EC300e
Sunshine Coast, Queensland
Australia
Old 02-04-2011, 11:13 AM
cal_tony cal_tony is offline
Since no one has replied I thought I might be of some assistance. However, I know nothing about the 2006 FSE. Re: the cam chain tensioner, if it like the earlier years, it needs no adjustment as it re-adjusts as the chain loosens.
If you have a manual chain adjuster than it would be similar to the one found on the DRZ 400. In fact the Manual ca chain adjuster that can be purchased for the DRZ from ThumperTalk will also fit the earlier model GG 4 stroke motors.
So if you have a self adjusting cam chain adjuster you might have to check to see if it is working properly.
If you have a manual adjuster you can go to thumper talk and review the numerous posts re: cam chain adjusting and the DRZ. There are even UTube videos re: the DRZ and manual cam chain adjusting.
Hope this helps
Tony
Old 02-04-2011, 11:37 AM
Gerko Gerko is offline
How can tell if the automatic tensioner is working ?
Old 02-04-2011, 02:51 PM
iancp5's Avatar
iancp5 iancp5 is offline
It's automatic. Not sure how resetting could make it better. It can't apply more tension from resetting.
Old 02-07-2011, 11:35 AM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
I believe it is the same tensioner as the DRZ400 and if you want to have control over the tension, TT sells a manual version for that model.
06 Gas Gas FSE 450 USA
Chain rub??? wence Enduro Chassis & Body 4 07-02-2009 03:07 PM
Best chain? nick790 Enduro Chassis & Body 7 06-17-2009 07:09 PM
chain slider / chain guide crossover? bondo General Discussions & Announcements 1 09-01-2008 09:13 PM
Replacing cam chain tensioner gasket bergerhag Enduro Engine 4 stroke (including EFI & Exhaust) 9 03-26-2007 07:48 PM
chain tensioner d251man Enduro Chassis & Body 7 02-26-2007 01:51 PM
