Old 12-13-2010, 06:25 PM
Default More noob Q's - Sachs fork 2010 300 Race
Hi everyone,
As the title suggests I'm after some info on the Sachs fork. I read somewhere that they have externally adjustable preload. Could anyone shed some light on this?
The user manual isnt much chop, and there seems to be so much variance between zokes and sachs and internals used over the years and models that its hard to find what I'm looking for.
Compresssion at base of fork. Rebound on top. Where is preload?
Old 01-01-2011, 06:25 PM
TNT Cycle TNT Cycle is offline
Not all bikes or not all race models came with external pre-load adjuster. Your top cap will have a retainer ring with four pin spanner wrench holes in it. If it is just a standard cap adjustable ones should be available.
Track-N-Trail Cycle LLC
trackntrailcycle.com
2011 Beta 400 RR (sorry )
2010 GAS GAS XC 300
2007 KTM 200 XC
Old 01-03-2011, 01:05 AM
NSE.ONE NSE.ONE is offline
Jakobi, our fork dosnt have external preload adjusters.
The Aussie 2010 Race did and is a different bike to ours. It is based on the 09 frame and plastics etc.
Our EURO's are based from the US and Europe spec 2010 race models, with a different fork again and a few other things but mostly bling.
We have unique fork and valving to our bike mate. Preload will have to be done with spring spacers.
Old 01-03-2011, 02:04 AM
moto9's Avatar
moto9 moto9 is offline
Pre-loading an already short and weak spring is not a good idea...If I would have had the fork apart before I ordered stiffer springs, I would have tried to find a longer one and removed the plastic spring spacers.
Also, IMHO, the rebound circuit is valved to light and a stiffer spring (or) preloading the stocker will only make it worse.
Plus, what little adjustment a preload adjuster has would not make much difference with the Sachs fork considering how far off it is.
With any suspension the valving needs to match the spring rates, which both are set to the riders specs...weight, skill level, terrain...ETC.
Sometimes you can get away with small changes....but to get the best out of your suspension, all should be done in unison.
If there is one thing on a bike that will make a rider faster, inspire more high speed confidence, cut time off your laps and allow a rider go faster longer...it's suspension.
It's the best money a rider can spend on his bike!
Old 01-03-2011, 02:34 AM
Thanks for the info lads,
I actually checked a mates 08/09 which has them and noticed that the adjustment is infact in the top of the fork cap as stated.
I also had no intention of making changes to the preload. I'm quite happy with the action of the fork at the moment apart from a bit of a mid stroke spoke on square edges. Was more so just asking out of curiosity.
Thanks again, Jake
Old 01-03-2011, 04:59 AM
Too true, small changes was all i was meaning.
2010 Sachs Fork Seals Bradz Enduro Suspension 7 01-04-2011 12:06 PM
New 2010 EC300 - NOOB Powervalve Vent Question JP4 Enduro Engine - 2 stroke 2 11-29-2010 07:48 PM
2010 sachs forks bowtech Enduro Product Announcements 13 09-09-2010 07:50 AM
2010 Sachs EC300 Fork Problem Bradz Enduro Suspension 4 07-17-2010 03:21 PM
2010 Sachs fork factory compression stack specs(ec300) bergerhag Enduro Suspension 9 07-01-2010 11:18 PM
