Old 12-16-2010, 11:18 AM
nick2510 nick2510 is offline
Default Older GasGas Questions
I just bought a what the guy says is a 2000 250. After doing some research online it seems that a 250 in that yr should be red not blue. The stickers have all peeled on the plastic so I'm not sure what it is now. It has a number plate installed so no headlight. I have tried searching the VIN with no results. Was wondering if there was some common things i could check just to make sure of what i have before I start ordering a few small parts?
VIN:UTREC259806985069
Old 12-16-2010, 11:37 AM
webmaster's Avatar
webmaster webmaster is offline
Administrator
The first two digits, "25" indicates it's a 250. Someone probably liked blue and swapped the plastic along the way.
Jeff
Old 12-16-2010, 11:53 AM
jhendr3702's Avatar
jhendr3702 jhendr3702 is offline
if i remember correct... the 2000 250 i had also had a 0 in the tenth digit.. a 2000 should not have a separate air box door to get to the air filter, you have to take the seat off...
gofasters.com has helped me with vin id before, but call them, the online catalog on the older ones is tough..
broken down over 60 slow rider..
Old 12-16-2010, 12:18 PM
einsteingarage einsteingarage is offline
Also look by the shifter on the motor it will say EC25 and some #'s below that.
Just for reference, I have an 06 300 with the red(250) plastic instead of the blue.
Old 12-16-2010, 12:19 PM
Prior to this bike, I had a 300 motor in a 250 frame.
That is why I would be more concerned with the motor than the frame.
Old 12-16-2010, 12:47 PM
You are correct. It has EC-25 a space and then 98. Followed by a series of numbers below that. I am assuming the 98 is the yr?
Old 12-16-2010, 01:09 PM
stainlesscycle's Avatar
what forks? rightside ups would be 99 and before.
what brakes? brembo is 99 and before.
although the front end could have been switched out - this is the quickest way to tell without vin lookup...
07 ec300
www.stainlesscycle.com
Old 12-16-2010, 01:31 PM
Brembo Brakes. Would the 2000 model brake pads fit? I am assuming not because of having nissin calipers. Thank you all very much for the help
Old 12-16-2010, 03:06 PM
brembo and nissin do not interchange.
07 ec300
Old 12-16-2010, 04:40 PM
Rick's Avatar
Rick Rick is offline
If you are in California you could get a green sticker.
Good Luck
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
4 Stroke GasGas questions Trailrider General Discussions & Announcements 11 08-20-2009 10:42 AM
older ec , cdi location widebear Enduro Chassis & Body 2 03-19-2009 10:38 AM
Older Silencer fit 07-08 ? cody1331 Enduro Engine - 2 stroke 1 07-21-2008 09:22 PM
-07 -08 plastics on older ec 300 matsa16 Enduro Chassis & Body 3 07-17-2008 09:10 AM
Considering older model Gas Gas EricP General Discussions & Announcements 2 06-03-2008 11:34 AM
