Old 01-24-2011, 10:43 AM
stainlesscycle's Avatar
Default fixing clutch drag when hot.
here's the symptoms:
i can kick bike in gear for dead engine start, have bike running, i click into gear, with clutch pulled, hit kill button. i keep clutch pulled and kick it and it starts fine.
but:
if i stall on the trail, in gear, pull clutch, and kick, clutch drags, and won't start. i need to shift to neutral to start it. this is a pain in the ass. i thought the plates would wear a bit and fix this, but it has not happened yet.
so, i'm assuming my clutch needs bled, and i've not been successful back bleeding it. i was thinking if i remove slave cylinder from bike, put a c-clamp on it, pump it once or twice so it's tight, then crack bleeder wouldn't the air be forced out of the line? can't figure out where air bubble is....
is there a foolproof way to bleed it?
07 ec300
www.stainlesscycle.com
Old 01-24-2011, 11:33 AM
Fred1956's Avatar
Fred1956 Fred1956 is offline
I wonder if you have the dreaded "basket notches"? With engine running and no load conditions, the clutch could fully release and hitting the kill switch would leave it released BUT when stalling with clutch released the plates could sitting against the basket & not release when the lever is pulled.
Just a thought to check on. Good luck
Fred Overstreet
2010 EC250 SixDays
2006 GasGas TXT 280 Pro
Old 01-24-2011, 12:25 PM
basket is not notched - i checked in november or so..
07 ec300
Old 01-24-2011, 01:58 PM
GMP's Avatar
GMP GMP is online now
Actually that sounds somewhat normal. It should be able to start in gear but it is harder. The idea of holding the clutch in during a kill for a dead engine HS start is to keep the plates "loose" and not stuck right? If the clutch system was leaking or needed bleeding it wouldn't matter, it would drag in both cases. If the master was leaking it would be worse the longer the lever was held in. Backbleed is easy, be sure you have free play in the lever. If the master cyl piston is not past the hole in the master cyl casting, no joy.
Old 01-24-2011, 02:12 PM
Bryan's Avatar
Bryan Bryan is offline
but:
Mine does the same thing. The basket is fine, no notches. Did it with new plates and worn out plates. Not sure there is a fix for it. I have heard of some trying different oils. Not sure if they had any success.
I have just chalked it up to a characteristic of my bike.
07 EC 300
06 Gold Wing
(2) 06 CRF 150 F
Old 01-24-2011, 02:16 PM
Todd5774's Avatar
Todd5774 Todd5774 is offline
Mine does the same, find if I rock the bike backwards abit it seems to release the gear and able me to kick in gear, quicker than shifting to neutral.
02 300ec- 50mm Marzocchi cc forks, 2010 plastic.
Now a 250cc.
Old 01-24-2011, 05:31 PM
Rick's Avatar
Rick Rick is offline
I am in the same boat, I go throught the same routine as you for all dead engine starts. 90% of the time, I can start my bike in gear, if I stall it. All I really do is keep my clutch adjusted per my owners manual. I'm sure I have the old school basket! I've not opened up the clutch cover in a few years.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
AZRickD AZRickD is offline
My clutch system works miraculously better when I bleed it.
I also use ATF in the tranny or ATF/Rotella.
Old 01-24-2011, 07:44 PM
whodat's Avatar
whodat whodat is offline
dam it rick, you just need to go faster so your bike does not get so hot.
Old 01-24-2011, 08:01 PM
correct. it works everytime. no problems with dead engine starts. i have freeplay at lever.
i can sometimes start it in gear if stall somewhere, but not always - depends on how tired i am or the angle i can get at the kicker.
i will try rocking bike a bit - there is nothing more frustrating than trying to find neutral/kicking when you stall.....
07 ec300
Yes my Clutch does drag. (F5) Enduro Engine - 2 stroke 42 04-09-2019 12:11 AM
Clutch Drag Is Not An Issue! Rick Pictures & Videos 7 11-25-2010 07:50 AM
Does your clutch drag? stay_upright Enduro Engine - 2 stroke 11 06-05-2008 03:14 AM
Clutch Drag? Gas Huffer Enduro Engine - 2 stroke 5 12-11-2007 05:02 AM
05' EC300 Clutch Drag gasIdaho Enduro Engine - 2 stroke 18 09-09-2006 02:53 PM
