Old 04-25-2011, 07:54 AM
mattdenn mattdenn is offline
Default Power valve did it stick?
Hi Guys
07 gas gas ec250, owned for a year and always run and been reliable. At the weekend whilst riding on a uphill gradient the bike note changed and i lost power. The engine continued to run but the exhuast sounded rattly and although the bike still moved it seemed to have no power at all. After stooping and starting the bike seemed fine again. about an hour later it done the same thing. with a good handfull of throttle it cleared itself again. it then run the rest of the day o.k. anyone got any ideas what might be going on?
thanks
Old 04-25-2011, 08:06 AM
GMP's Avatar
GMP GMP is offline
Classic dirty, sticking PV.
Old 04-25-2011, 01:11 PM
Thanks
Is it just a case of cleaning it? and does it mean complete disassembly of the powervalve?
Old 04-25-2011, 01:23 PM
GMP's Avatar
GMP GMP is offline
Yes and yes. Good news with a GG is you can pull all the PV parts from the cyl without removing the cyl from the motor. R&R the main flap is easier with the head removed though.
Old 04-25-2011, 01:35 PM
Thanks Glenn
Never cleaned one before so it will be a sharp learning curve.
Old 04-25-2011, 06:25 PM
gasgasman's Avatar
http://translate.google.com/translat...staticID%3D133
Old 04-26-2011, 02:36 PM
Great link, thanks.
I removed the exhaust and PV left and right covers tonight, all seems to be moving freely, does not seem to be sticking or any restriction, probably a different story when the engine is under load. Even though is all seems to be free i thinks it will be best to disemble and clean.
Have there been any issues on bikes with the mechanism in the side casing that controls the PV arm?
Thanks
Old 04-26-2011, 02:50 PM
GMP's Avatar
GMP GMP is offline
Don't pull up on the PV rod, you can cause the balls to dislodge from the governer. Disconnect the rod first, then check movement. Heat the nut on the plate to soften the loctite.
Old 04-27-2011, 11:57 AM
Oh no, thats exactly what i did. How do i now if i've dislodged the governor bearings? should i fire it up? I was gonna start the disembly tonight to get the PV cleaned.
Old 04-27-2011, 02:21 PM
Hi
Tonight, i remove the exhaust valve lever from rod on right hand side and also the left and right bearing holder bolts. I then removed the long rod by tapping it throught from one of the bearing bolt holes. It then says to pull out the right hand exhaust valve (can be aided by screwing back in the bolt). this is where i am stuck, there is about 5mm play but the damn thing will not come out. should it come out easy or are the prone to be tight. any suggestions? i think it might be the bushing between the bearing and valve (right side) causing the problems.
LTR Power valve cover skid jackson Enduro Product Reviews 22 09-04-2017 02:42 PM
Power Valve Spacer Dingo Enduro Intake/Carburetion - 2 stroke 16 01-22-2009 01:53 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
Sticky power valve?? moff747 Enduro Engine - 2 stroke 9 12-22-2007 07:59 AM
Power Valve rebuild Gas Stu Enduro Engine - 2 stroke 2 09-19-2007 12:38 AM
